Old    Stephen (sk4910)      Join Date: Jul 2011       05-23-2012, 8:04 AM Reply
I have a fly high ballast bag and one of the ports is stripped. It there a way to fix this without having to replace the bag? I bought the boat used and apparently the previous owner tried to silicone the fitting into the stripped hole but it popped right out on me.
Thanks in advance!
Old     (superfluous)      Join Date: May 2012       05-23-2012, 9:47 AM Reply
Same problem with my 7 year old bags. The plastic threads get compromised over time.
Instead of silicone, use Marine Tex for a permanent solution.
Old    Eric Silva (getssum)      Join Date: Jul 2005       05-23-2012, 4:35 PM Reply
Flyhigh will fix your bag as well if you don't mind sending it to them. Plus they can upgrade ports, put more holes in it, etc. Pretty reasonable as well!
Call em up they're nice people!
Old     (TheSqueakyWheel)      Join Date: Oct 2010       05-25-2012, 5:40 AM Reply
If you want a permanent solution, superfluous' fix will work. I've done similar with PVC cement from ACE hardware. A thick coat seals the threads for good.
Old    Stephen (sk4910)      Join Date: Jul 2011       05-25-2012, 8:22 AM Reply
What is superfluous' fix and where can I buy it?
