Old     (markj)      Join Date: Apr 2005       05-09-2012, 9:50 PM Reply
Okay so based on previous statements and recommendations on this site, I tried this stuff called Totally Awesome. It lives up to it's name. I almost felt like I was cheating by using this stuff. My only concern is that my upholstry is gonna blow up or something. It shouldn't be this easy. Has anyone had any bad experiences with this stuff? I only did a small section and i rinsed with water after using it full strength. Is that the right way? The directions say dilute 10/1 for vinyl but that means you need a ton of elbow grease. I just don't want to find out too late that I should have done something different.
Old     (tyler97217)      Join Date: Aug 2004       05-10-2012, 7:20 AM Reply
I have used it for years and yes it works. Do a search on here and you will find many good reads on it. Many others have used it for years. No problems on boats. I don't dilute it either.... Totally Awesome and a brush. Keep it off the gel coat or it will be oily and streaky.
I did use it ones on a cream door panel of a BMW and it turned it green. It was some weird material and I was able to get the color back with some other cleaners, but it scared the ***** out of me. I use it for vinyl and plastics now typically.
Old     (markj)      Join Date: Apr 2005       05-10-2012, 7:30 AM Reply
Okay thanks.
Old     (xstarrider)      Join Date: Jun 2007       05-10-2012, 8:07 AM Reply
Stuff works magic. Just make sure u use a good protctant/conditioner afterwards and watch the overspread. If you are trying to get a hard spot u can use it undisputed.......however if you are using it as a cleaner on a ref basis I highly recommend diluting it.
Old     (jmanolinsky)      Join Date: Dec 2005       05-10-2012, 9:03 AM Reply
I dilute mine approximately 60% water to 40% TA. It works great!
Old     (markj)      Join Date: Apr 2005       05-10-2012, 9:59 AM Reply
Of course I'm doing this AFTER I waxed it. Now I think I'm gonna need to wax it again where the TA got onto the gel coat. This stuff seems to leave a residue that needs to be "washed" with water afterwards.
Old     (tyler97217)      Join Date: Aug 2004       05-10-2012, 10:14 AM Reply
Markj
Just use some windex or your standard exterior detail spray and a microfiber. It will clean right up.
Old     (BlitzedVLX)      Join Date: Feb 2011       05-10-2012, 12:09 PM Reply
This stuff makes cleaning the vinyl really easy but its super harsh on the threads. I immediately rinse the seats with water then let them dry completely. Follow up with a coat 303 protectant and they look like new.
Old     (markj)      Join Date: Apr 2005       05-11-2012, 12:13 AM Reply
Ya after I cleaned the cushions I sprayed them with the hose and let them dry. It's the in boat stuff that I worry about. I took a wet rag and wiped down the in boat stuff after cleaning. Hopefully that's good enough. I'm a little worried about the stitching though.
Old     (mnwakerider)      Join Date: Jun 2004       05-13-2012, 6:58 PM Reply
where did you guys get this stuff?
Old     (ixfe)      Join Date: Aug 2008       05-13-2012, 7:50 PM Reply
Dollar Tree... or any other dollar type store.
Old     (Preston)      Join Date: Jul 2010       05-14-2012, 4:57 AM Reply
My Walmart sells the stuff, too.
Old     (zacharoo)      Join Date: Nov 2005       05-14-2012, 7:32 AM Reply
As an uber fan for Total Awesome I thought I would open up to see if there was an equal or even better vinyl cleaner for my interior. I ordered the Boat Bling Condition sauce because of my faith hope and love for TA and when my order arrived I found a bottle of Vinyl sauce as well. The stuff works totally...err Fantastic! What I liked about it other than its cleaning ablity which was impressive, is that the VS after using it for an extended period did not chewed up l my hands like the TA does after a while.
Applause to Boat Bling for their products!
Thread highjack over
Old     (scottb7)      Join Date: Oct 2012       07-05-2013, 11:40 AM Reply
I can't believe it...But it is true. I just now used full strength. It got out stains and grime I could not get out before even when I used a brush. I did not need to use a brush with totally awesome. I did rinse off after use. And later today - when i get more energy - i will go thru and condition the vinyl. I highly recommend.
Old     (Bumpass1)      Join Date: Oct 2010       07-05-2013, 2:29 PM Reply
Do the same thing. Works great. Cheap too.
