call PP, they will set you up, tell them how much weight you are running and the prop and they will give you some recommended settings and how to adjust it little by little. i did that with mine and i believe they told me to leave one of them alone (don't remember if it was the kdw or nn factor but one of them they said leave at factory settings and just work with the other. over time i ended up changing both just a tad and it works great. IMO RPM mode works great and is a consistant pull under two conditions, the first is that you are going pretty fast (like 24-25 mph maybe more. my rpm mode doesn't really work well unless its about 25 or higher and in my boat, we ride at about 22 so it doesn't really work for me. the other is how hard someone is pulling. if you have someone riding that is a heavier dude, or someone that rides with a strong edge and pulls HARD back on the boat, you will have to do ALOT of adjusting on the fly. but either way make sure you are paying attention when someone is riding. i always have my hand on the throttle and know that in my boat if someone is pulling out to the left side i have to give it a little more gas while they are pulling, if they are pulling out to the right i have to let off just tad...granted PP is suppose to do this for you, but this is really only when i have someone back there that is really pulling hard.
