Old    Scott R (ScottR)      Join Date: Aug 2011       05-04-2012, 2:30 PM Reply
Guys, buying a 2009 Ford F150 and have Gear Alloy BlackJack Rims on my trailer on my boat. Wanting to match my truck.
So, know nothing about this stuff. Need some help. I want to use the stock tires on the truck just change out the rims? Possible?
Here is the truck link so you can see it...http://apps.dealerconnection.com/dea...ownedImg=false
Here is the link to sizes of the Rims I want....
http://www.gearalloy.com/718b
Can anyone tell me what I need to know...? Thanks
Old    Bryan James (bjames)      Join Date: May 2012       05-04-2012, 2:39 PM Reply
I have a F150 (2006 King Ranch) that came with 20". One thing i do know is if you want to keep the same rubber but only replace the rims, you will have to find rims of equivilent size and offset. The offset is quite important becuase this is the offset to where the centerline of the hub is located. If the offset is not matched up properly, then your wheels with either stick out or be inset too much causing other potential problems. Also you will have to match up the hub hole pattern.
So if your shopping around make sure you know;
Rim size dia & width
hole pattern
offset amounts.
Old    Scott R (ScottR)      Join Date: Aug 2011       05-04-2012, 3:01 PM Reply
Bryan....Thanks. Guess that is what I am asking. I know what rims I want...(link) just dont know what size fits the tires I have...
Old    Rick Hoag (rickB52)      Join Date: Mar 2012       05-04-2012, 10:34 PM Reply
It looks like your 150 has 20" rims/tires. If you go with the Gear Wheels you will need to go with the 20x9 however not sure your stock tire will work... the stock tire (P275/55R20 111S) is made for a much narrower rim like 8". I would place a call to Gear -American Tire Distributor to validate recommended tire size for their 20x9 wheels...
Old    Scott R (ScottR)      Join Date: Aug 2011       05-05-2012, 4:59 AM Reply
Thanks....thought I may have to buy new tires too. Yuck
Old     (nitrousbird)      Join Date: Sep 2008       05-05-2012, 5:21 AM Reply
A 275 width tire will easily fit on a 8" or 9" wide wheel. Hell, it would fit on a 10" wide wheel, it would just look weird.
The 275 width tires on my last set of wheels for my Formula are 275/40/17 on a 17x9 rim - this was a factory size. It will be fine.
Old    Scott R (ScottR)      Join Date: Aug 2011       05-08-2012, 10:46 AM Reply
My tires are 275 5 R20...
Old    Scott R (ScottR)      Join Date: Aug 2011       05-08-2012, 10:55 AM Reply
Tires
Old    Scott R (ScottR)      Join Date: Aug 2011       05-08-2012, 10:57 AM Reply
Truck
Old    Stuey (stuey)      Join Date: Dec 2004       05-08-2012, 11:53 AM Reply
Scott - you are good to go with those stock Pirelli tires no problem. A 275 tire is 10.8" wide so it's perfectly fine on a 9" wide wheel.
The wheels you are looking at are 20x9 with a +18mm offset which will make them kick out about a 1/2" more than your factory wheels. I wouldn't be concerned with it, so as long as you are fine with that you are good to go. It won't affect the ride or anything else noticeably.
Old    Scott R (ScottR)      Join Date: Aug 2011       05-09-2012, 7:32 AM Reply
Stuey...Thanks a million man. So now I can order them! Woo hoo.....I think matching the boat trailer will look awesome. I am going to sell these rims so if anyone is looking let me know.
