Old    Adam Van Dyke (lfadam)      Join Date: Nov 2008       05-03-2012, 7:37 AM Reply
Are inboard rear drain plugs standardized? It appears some fisherman down at the marina stole ours. Im hoping I can find one at a Marina or Lowes since Im about to go out to the lake.
Thanks
Old    Art (rallyart)      Join Date: Nov 2006       05-03-2012, 8:18 AM Reply
Mine is the same as my 1980 boat was and I could get it anywhere.
Old    Seth M (Sethjoe)      Join Date: Apr 2011       05-03-2012, 8:21 AM Reply
1/2" is the standard drain plug size.
Old    Diggs (pdxWAKE) (tyler97217)      Join Date: Aug 2004       05-03-2012, 8:46 AM Reply
I think there are two sizes. I know I have had boats that the standard plug does not fit. I want to say that MC or Malibu use something different, but I might be wrong on that so don't quote me. I would call your dealer.
Old    BILL RUTH (wdr)      Join Date: Dec 2011       05-03-2012, 8:58 AM Reply
My '06 Moomba and my '10 Malibu LSV both had/have stamped "1/2" NPT plugs. I have mine permanently attached now. I drilled a hole in the plug, soldered in a 6" piece of coated solid copper electrical wire and soldered on an eye ring onto the other end. I put it through the hull and secure it with a key ring loop into the eye ring to keep the "honest people honest". Pull it out and it hangs w/o any flopping around or banging on the hull.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       05-03-2012, 9:17 AM Reply
MB uses a bigger plug. 3/4"?
Old    Adam Van Dyke (lfadam)      Join Date: Nov 2008       05-03-2012, 2:53 PM Reply
Turns out it was indeed the 1/2 inch. Thanks
Old    Baitkiller (baitkiller)      Join Date: Jan 2010       05-03-2012, 3:54 PM Reply
How do you know it was a fisherman?
More obvious follow-up rhetorical questions held.
Glad you have a drain plug now.
