Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-23-2012, 10:21 AM Reply
Bill at acme recommended this prop to me for my 05 star I recently purchased. The engine is a 8.1l 450 , and we will be running 5 to 6k of ballast. What to you guys think? Has anyone used this prop before?
Old    Johnny (johnny_defacto)      Join Date: Sep 2006       04-23-2012, 12:32 PM Reply
slightly off subject.... I want to ride that wake please....
What prop is on it/will be on it? can you load it up as much as possible and take wakes pics? then do that again with the new prop with the same weight and take pics, rpm, plane times...etc?
thanks.
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-23-2012, 5:49 PM Reply
the prop on it now is an oj 13.7 x 19.5
and somehow it barely got on plane with four 750s
with out ballast we could get up to 50 mph which is a bit rediculous...
theres not enough clearance between the rudder and shaft to get this pro off... im probably going to have to remove the rudder
im not sure what rpms we were doing
Old    Zach (zacharoo)      Join Date: Nov 2005       04-25-2012, 5:57 PM Reply
I'd like to hear your results as well...I talked with Jim at Acme and I asked what other prop would help my non wake plate version MC X15 have better hole shot.
I'm currently running an Acme 1285 with the MCX motor and have around 2200 pounds of ballast and the boat struggles to plane off.
Jim suggested a Acme 2305 which is 15 x 12 with 1.05 cup...i think thats right...if the hull clearance allows for it.
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-26-2012, 12:38 AM Reply
dang im glad i got the big engine... it was pullin 3000 out of the hole stock
Old    JS (dreamer)      Join Date: Nov 2008       04-26-2012, 8:18 AM Reply
How much clearance do you have between your current prop (13.7" diameter) and your hull?
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-26-2012, 1:17 PM Reply
wish i could say but its off now and i had to remove the rudder to get it off so its probly never going back on
Old    JS (dreamer)      Join Date: Nov 2008       04-26-2012, 3:06 PM Reply
If you can get a 14.5 or 15" diameter prop on it then that is the direction you should take but if you are limited to a smaller diameter then the OJ 5-Blade prop might be a good choice.
I have an Enzo and it is limited to 13.5" diameter props which just do not have the pulling power of a 14.5 or 15" prop so I tried the OJ 5-blade and was really impressed with the extra holeshot it gave me over my Acme 1579 prop (13.5x14.25").
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-27-2012, 7:37 PM Reply
heres a pic of the 2243, i have about an inch of clearance
and the prop that used to be on there is on the ground paha it looks like a baby!
i installed my home made plug n play system last night and now im waiting on sacs and more sacs to come in the mail
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       04-28-2012, 10:23 AM Reply
here are the specs on the 2243
Diameter: 15"
Pitch: 14.25"
Cup: .105
i will tell yall how it works out when we get all of our gear in
Old    TRDon (trdon)      Join Date: Sep 2007       04-28-2012, 7:01 PM Reply
Holy crap, what a drop in pitch, that'll work.
Old    J.B. O'Neill (gnarslayer)      Join Date: Sep 2008       05-01-2012, 7:59 PM Reply
all the sacs came in the mail yesterday and we took out the boat today to test the prop. we ran 4k in ballast with 6 people the wake was extremely large and we didnt feel the need to add more weight... anyways the boat gets on plane in 4 to 6 seconds, this boat and prop are beast status! couldnt be any happier!
4500rpms to get on plane and once on plane it dropped down to 3500
acme is the bomb i wouldnt go with any other prop
