Old    Zach (zacharoo)      Join Date: Nov 2005       04-30-2012, 9:39 AM Reply
I thought I would ask if anyone had a prefence on a couple of amplifer distribution blocks. I'm adding an additional amp and need to add them to my system. Three amps in total: Tower, Subwoofer and interior amp.
Old    Ryan Bush (ryanbush11)      Join Date: May 2003       04-30-2012, 10:30 AM Reply
Stinger makes quailty products, you can get good prices from darvex.com
Old    Cory McLean (kikitlo)      Join Date: Jul 2005       04-30-2012, 12:07 PM Reply
So far I'm happy with this one. Power, ground and volt readout
http://www.sonicelectronix.com/item_...TPFDB-4PG.html
Old    Daryl Hall (flintwake)      Join Date: Mar 2013       03-13-2013, 7:22 PM Reply
Do you just run one positive wire and one negative battery to this block from the battery and then one pos and one neg from block to each amp ?
Old    Bryce Pool (bryce2320)      Join Date: May 2012       03-13-2013, 8:41 PM Reply
x2. I think about everybody would agree. I skimped the first time and got some little bitty stinger distro blocks. Redid my amp rack this winter and love this one
Old    Bryce Pool (bryce2320)      Join Date: May 2012       03-13-2013, 8:44 PM Reply
It has a spot for dual 0 or 4 gauge B+ inputs, and 4 4gauge outputs. The ground is the center one and only has a spot for 1 0 or 4 gauge ground, and again 4 outputs. I have a dedicated battery bank and perko, so I ran from the B+ on one of the stereo batteries to the perko, then to the distro. The ground will go straight to the common ground of your battery bank battery, or the battery all your grounds terminate at.
Old    Louis Teague (loux2)      Join Date: May 2004       03-14-2013, 12:28 PM Reply
I used street wires. Good quality.
Old    Louis Teague (loux2)      Join Date: May 2004       03-14-2013, 12:30 PM Reply
Just for fun, here is a shot with the new batteries.
Old     (Thrall)      Join Date: Oct 2010       03-14-2013, 1:18 PM Reply
Me too, but used a fused dist block for the + side to the amps.
Old    Zach (zacharoo)      Join Date: Nov 2005       03-14-2013, 2:39 PM Reply
Louis..That's a nice looking setup!
Old     (pprior)      Join Date: Jan 2012       03-14-2013, 3:25 PM Reply
That battery cage is sweet. Custom?
Old    P90 (DatTexasBoy)      Join Date: Aug 2012       03-14-2013, 5:51 PM Reply
I heard the Interstate batts were just as good or better for this application.
Old    Louis Teague (loux2)      Join Date: May 2004       03-14-2013, 6:12 PM Reply
Prior, I purchased the box at Rex Marine. I really like it. I am sure the Interstate batteries are good. But I like the way the Blue Tops look.
Old    Louis Teague (loux2)      Join Date: May 2004       03-14-2013, 6:13 PM Reply
Thank you Zach.
Old    Dax Jolly (volzalum)      Join Date: May 2009       03-14-2013, 6:34 PM Reply
You can also get custom optima boxes made. I had a triple version made with the Centurion logo on it. I too like the look of the Blue Tops ...
Old    Dax Jolly (volzalum)      Join Date: May 2009       03-14-2013, 6:35 PM Reply
Second pic
