Old     (Tehanw215)      Join Date: Jul 2011       04-28-2012, 4:44 PM Reply
I know this has been discussed before, but im wondering if anyone has put in custom sac set up on 05 sanger v215 with drain and fill switch on dash and about 1200 pounds of water in back locker. I know there would have to be some modifications to boat. Any info would be appreciated. Id rather not use my led anymore.
Old     (polarbill)      Join Date: Jun 2003       04-29-2012, 6:13 PM Reply
I could be mistaken but the Team Pro Shop in Longview WA use to stuff some sort of sack under the floor. Apparently there is a some way to get under the floor and stuff a sac on the outside of the stringers. I think I have heard you rcan get 350-500 pounds per side. If you could do that plus the largest sack possible in the locker or a Enzo style surf sac you should be set.
Old     (clotus)      Join Date: Mar 2009       04-29-2012, 6:59 PM Reply
wavemakers has a kit that replaces the hard tank with all the fittings and hoses needed. You can get a 750 or 1000 sac I believe. I have the 750 on the port side (my crew only surfs port side) and we love it.
http://www.wakemakers.com/sanger-tan...m-upgrade.html
Old     (Tehanw215)      Join Date: Jul 2011       04-30-2012, 5:44 PM Reply
thanks polarbill and clotus. Have been in contact with with team shop in wa. considering the trip. Lookin at a little over 2 grand and a 7 hr drive there and back. I know not having to mess with lead, bags, and pumps is worth it but is the effect on the wave?
Old     (Kemikal)      Join Date: Jun 2011       05-06-2012, 9:55 AM Reply
I have the same boat (05 V215) and have the 1000lb wakeamakers package in mine along with the 500lb stock sac in the floor. Surf wake is great.
Old     (Tehanw215)      Join Date: Jul 2011       05-07-2012, 1:04 PM Reply
Any pics kimical? I dont have existing hard tanks so i need to run all plumbing and switches on dash. do they sell a kit for that? the pro shop in washington will do it for me but they are about nine hrs from me. They will also put a 350 lb sac under floor which runs from back locker to windshied. Wondering if there is a place closer to me that could do it? I am located in the town of Mckinleyville in north cal. The place in WA claims they are the only ones that do the custom sac under floor for the sanger
