Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       04-27-2012, 5:52 PM Reply
Tow vehicle is an ML350 bluetec with factory installed towing package ... pulls great and getting awesome mileage being a diesel ... but the trailer LEDs are flashing when the brakes aren't engaged etc.
Looked up MB forums etc. and they refer to a part on eztrailer.com which I can't seem to pull up - basically an additional resistor to be put between trailer and vehicle plug ...
Anybody know what I'm refering to - appreciate the input!
Nick
Old    Axel (axeman)      Join Date: Aug 2009       04-30-2012, 8:03 PM Reply
Are you referring to this?
http://www.etrailer.com/Wiring/Tow-Ready/TR20141.html
Read the reviews on that part as it seems you may want to continue looking but at least that'll give you an idea on what to look for. Us MB guys aren't as lucky as the VDub/Porsche guys that were able to get this fixed with a software update. Also, what kind of ball mount are you using and the height of your trailer? I've got an ML 550 and was told to get at least a 6" rise for a 21" tall trailer at the tongue.
Old    Axel (axeman)      Join Date: Aug 2009       04-30-2012, 8:11 PM Reply
More specific with part numbers here. It's for an R-class but the bulb out bypass adapters (what you are asking for) should be the same:
http://mbworld.org/forums/r-class-w2...g-harness.html
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-01-2012, 7:36 AM Reply
Axel,
Yes that's the one - just can't seem to find it anywhere - the MB link at least now contained the full part number. The one from etrailer.com is 7 to 5 but I need 7 to 7 - so that's probably a bit of a hassle.
I'm considering putting the resistors into the trailer wiring myself so I don't have to deal with the converter at this point as they don't seem to be available.
Thanks for the links - what I haven't done yet is contacting the manufacturer of the trailer directly - they may have a suggestion as well.
Nick
Old    Axel (axeman)      Join Date: Aug 2009       05-01-2012, 10:47 AM Reply
What about this above?
Also, are you running electric disc brakes on your trailer? If so, did you buy a separate brake controller?
Old    Axel (axeman)      Join Date: Aug 2009       05-01-2012, 10:55 AM Reply
Actually, here's the one you are looking for...
http://www.vwdiscountparts.com/partl...catalogid=5496
I know it says its for a VDub but if you read carefully it says it comes in Valley Industries packaging which to me means its the Valley Industries part and not VDub specific.
I also read on one of the VDub forums that you can call etrailer.com directly and if you ask them about the part they have it (even though it doesn't show up on their site). So, I'd try them first since they typically have the best prices...
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-01-2012, 3:09 PM Reply
found it locally after stopping at the MB dealership - they are just ordering it up the street and it is ultimately from Valley towing - so the part everyone is selling. Still overpriced as it basically contains a resistor but I'm lazy ;-)
And yes - the ball rise - didn't go for 6" ... had from my prior vehicle a 2" drop and that seemed quite low so changed it to a 2" rise which works ok. Bummer is that the 350 is not equipped with the automatic adjustment - only the ML550 is - so it's kinda sagging back there ;-) but hopefully the whole towing is mute in a few months if I can find reasonable lakeshore property here in the Twin Cities
Old    Axel (axeman)      Join Date: Aug 2009       05-01-2012, 7:58 PM Reply
Yeah I thought 6" rise was a bit high but that's what the guy at the boat shop recommended. We'll see when it comes in. I ordered the 7 to 5 pin adapter today from etrailer.com so we'll see what happens. Getting ready for new (to me) boat hopefully by this weekend (keeping fingers crossed). My ML550 doesn't have the air suspension. What auto leveling are you referring to? Are you referring the air suspension?
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-02-2012, 4:37 AM Reply
yeah guess that's what MB calls. I didn't ask the guy at the service desk for which model year it is applicable (mine is a 2010) he simply said that only the ML550 has it ... so you getting a new ride this weekend?
Old    Axel (axeman)      Join Date: Aug 2009       05-02-2012, 9:41 AM Reply
Interesting. I'll have to call my guy at the dealership to find out about this. Mine is an 09. Picking up an 08 SAN 220 TE Friday if all goes well
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-02-2012, 12:46 PM Reply
good luck - guess you'll have fun earlier than I do - just ordered a 4/3 wet suit as the water temps are still too cold here in MN ... not sure if I shall laugh or cry but this is what I picked up a few minutes ago ... didn't really need 3 ft of cable ...
Old    Axel (axeman)      Join Date: Aug 2009       05-02-2012, 1:29 PM Reply
Woah! That looks legit! Looks like you'll need to tie that down to the trailer... I'll let you know if the part I ordered from etrailer.com actually works or not (should be here tomorrow).
Old    Axel (axeman)      Join Date: Aug 2009       05-02-2012, 1:33 PM Reply
Checked with my buddy at the dealership and he said my ML550 doesn't have auto leveling. I'm pretty sure that the guy was referring to the air suspension...
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-02-2012, 9:14 PM Reply
bummer - hope your boat/trailer doesn't have a heavy tongue load - my epic is w/o all the stuff and gas 3400 lbs and the trailer clocks in at 1600 lbs ... still have to get on a scale to get the actual tongue weight - pulling is a no brainer but it really goes down when I hook the trailer up.
And yes - looks legit but was hoping for just the plug instead of 3 ft of wiring in between - will prolly take it apart and see if I can shorten it :-)
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-04-2012, 11:22 AM Reply
couldn't resist and I'm prolly just putting the resistors into the plug on the boat - just couldn't believe w/o taking it apart ...
Old    Axel (axeman)      Join Date: Aug 2009       05-07-2012, 1:17 PM Reply
I picked up the SAN on Friday and mine didn't need this adapter (the one on eTrailer.com). So I'm good for now I guess!!! I have a Dorsey trailer if that helps/matters...
Old    Nicolas Kohler (monkey_butt)      Join Date: Sep 2011       05-07-2012, 2:32 PM Reply
so you got the boat?! cool - congrats - but is the trailer LED equipped?
I actually shortened the whole thing to about 1 ft length overall and was contemplating just to wire it into the trailer - but for now it works ok - so not going to play around with it - rather put my FAE on the boat - so I'm not getting nauseated when surfing
Old    Axel (axeman)      Join Date: Aug 2009       05-08-2012, 3:59 PM Reply
Yes the trailer is LED equipped. FAE is on my list of addons as well!
Old    Greg Bodor (gti2lo)      Join Date: Nov 2005       05-08-2012, 5:48 PM Reply
I got the same adapter with the 3' cable. I mounted the assembly on the trailer tongue with self tap metal screws and the 7-5 pin adapter stays plugged together
