Old    Matthew Melvin (melvinator)      Join Date: Apr 2001       04-26-2012, 4:37 PM Reply
Just finished building a stand up paddle board and I have some foam and gator grip left and want to make a wakesurf board and not sure on shape. I mostly ride on a friends old 5"6" broadcast and it seems ok, we can drop in from the platform, ride with no rope and cross the wake and ride toeside/heelside no problem. I don't want to just copy that board shape and rocker. I am about 165 lbs and mostly will be surfing on my vlx wake, i am not hard core, just like to carve around and have fun a few times a week after a wakeboard set. medium size wake usually, wedge and around 1000 lbs of ballast
opinions on size,shape, rocker, fins?
Old    N L (drnate)      Join Date: Jul 2006       04-27-2012, 7:00 AM Reply
Well, one thing is for sure. If you're going to copy a board, I would not copy the Broadcast
For your size, shouldn't be larger than 5', I would say around 4'6" or so. 19" wide, 1.5" thick. I would go with a three fin set-up so that you could always remove the center fin if you so desired. Maybe others can comment on rocker, etc.
Old    Matthew Melvin (melvinator)      Join Date: Apr 2001       04-27-2012, 10:03 AM Reply
Might copy from different boards, 3 fins is a good idea so I can take out the middle, never thought of that. Why is the broadcast bad?
