Old    Jonathan Howell (nu2dagam)      Join Date: May 2004       04-09-2012, 9:38 AM Reply
I can not get one of my plugs to go in. The plug has threads on one
End and a piece on the other that plugs into it. Any clue?
Old    Jonathan Howell (nu2dagam)      Join Date: May 2004       04-09-2012, 9:43 AM Reply
[URL="http://m1069.photobucket.com/albumview/albums/jrh1010/Mobile%20Uploads/IMG_7164.jpg.html?o=0&newest=1[/URL]
: ) I give up. I'll post a pic tomorrow if no one has a clue.
Old    Cory D (cadunkle)      Join Date: Jul 2009       04-09-2012, 9:55 AM Reply
If this is the piece you're talking about, it's a knock sensor. Detects predetonation which the ignition box or ECM will retard timing when it occurs, avoiding engine damage like cracked pistons and rings, damaged bearings, etc. If your ignition setup uses this, it should be installed. Commonly installed in block drain holes, do not replace with a drain plug unless you're running an old style ignition with no provision for a knock sensor.
Old    Jonathan Howell (nu2dagam)      Join Date: May 2004       07-07-2012, 7:19 PM Reply
Ok, u haven't had our boat out all year o_O been working on getting. Pool
Built. But I still haven't replaced this part. Can I put a drain plug in till this part comes in? Will the engine even start?
Old    Jay (parkcityxj)      Join Date: Mar 2001       07-07-2012, 8:27 PM Reply
Don't run it without. It looks like a standard 350 knock sensor, I'd cancel the order and go down to an auto parts store to get on the water sooner.
Old    Jonathan Howell (nu2dagam)      Join Date: May 2004       07-07-2012, 8:27 PM Reply
Thanks J. I'll do that.
