Old    Steve (scvlx)      Join Date: Jan 2012       04-06-2012, 7:27 AM Reply
I am hooking my center ballast back up and want to double check on where to hook up the drain/vent hose. Does it go in the bottom plug of the fly high bag? It seems like it would flow out the drain pump before it would get full. The boat is a 2001 wakesetter vlx. Thanks.
Old    Spencer (spencerwm)      Join Date: Feb 2009       04-06-2012, 12:20 PM Reply
Drain hose goes in the bottom port on the end. Fill and vent go on the top of the bag. If there is enough water pressure it will force water out the drain but it will take a lot to do that. You should be good. If you are getting some passive draining adding additional hose to the line will solve the issue. Have a good weekend.
Thanks,
Spencer
Old    Steve (scvlx)      Join Date: Jan 2012       04-07-2012, 8:19 AM Reply
Thanks for the information Spencer.
