Old     (bazel)      Join Date: Oct 2001       08-19-2003, 7:32 PM Reply
I have a small crack in my bellows, on my I/O. This keep the drive shaft dry. I am wondering if anyone knows of any kinda of spray of something to patch it temporarily. I want to try to make it last thru my VK, because the work on this will take a few weeks.
Any help or suggestions would be greatly appreciated!!
Thanks
Old     (salty87)      Join Date: Jul 2002       08-21-2003, 6:25 AM Reply
maybe some of the stuff you fix drysuit leaks with. go to a diveshop or even a sporting goods store and ask for aquaseal. it's a clear sealant/adhesive that is also very flexible, comes in a tube.
Old     (wakescene)      Join Date: Feb 2001       08-21-2003, 8:11 AM Reply
If you have a crack in your bellows, get the boat out of the water ASAP!!!
If you get water up to the Gimble Bearing, it will turn to toast in about a week, then you are out a ton of money getting it fixed. If it is truly a cracked bellows, is should be replaces anyway, and you will have to take the boat out of the water for the repair.
Call around, this time in the season, there are shops looking for work and you should be able to get the boat in and out in a few days.
KG
