Old    Cliff (ord27)      Join Date: Oct 2005       01-23-2012, 11:27 AM Reply
2006 F250
I have always been overkill and changed the oil every 3000 miles
Ford has always told me 5000 miles
The other day, I had a Ford Tech tell me to change it every 200 hours
I now have 100 hours since last change and have 4000 miles. That would be 8000 miles at the 200 hour mark.
I use synthetic oil
what do yall think?
Old    Tim (srock)      Join Date: Mar 2002       01-23-2012, 12:16 PM Reply
3000 is way beyond overkill with synthetic-its bayoneting the dead. You must be taking the lube centers recommendation. I would be at a minimum 7500 with synthetic with heavy dusty usage?
Old    Kevin Skonnord (kskonn)      Join Date: Mar 2011       01-23-2012, 12:36 PM Reply
what engine? Powerstroke or Gasser?
Old    Cliff (ord27)      Join Date: Oct 2005       01-23-2012, 1:54 PM Reply
powerstroke
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       01-23-2012, 6:31 PM Reply
Way overkill if you're changing syn @ 3k. Either leave it in for 7500 or if you dont like leaving ANY oil in that long, (like me) just run a good grade conventional and change every 2 to 3k depending how bad you work it. This is how I service my Cummins.
Old    Robert T (cwb4me)      Join Date: Apr 2010       01-23-2012, 7:01 PM Reply
I change my 05 powerstroke every 5000 with 15w40 rotella but hours is how they recommend changing diesels that idle alot.You shouldn't let your powerstroke idle alot because it will carbon up the EGR valve.
