Old     (Laker1234)      Join Date: Mar 2010       01-10-2012, 7:49 AM Reply
My 10-year-old driveway is cracking. Any suggestions on what I can use to fill in the cracks--about 3/8 inches wide. Also, do I need to put some kind of sealant on the concrete?
Old     (buffalow)      Join Date: Apr 2002       01-10-2012, 7:55 AM Reply
I actually am doing mine in the spring. I think you need to clean it real good, let it dry and than either use the flexible concrete "caulk" or mix up the concrete patch repair.
Old    SamIngram            01-10-2012, 8:15 AM Reply
It depends... why is it cracking? Do you have expansive soils, put to much weight on the drive-way, have no relief cuts, live in an area where it freezes and have water pooling under the drive-way, acidic soils that are destroying the concrete, or just have a crappy install or design?
Old     (Michael)      Join Date: Mar 2010       01-10-2012, 9:47 AM Reply
Sam if it was bad install he would have known a lot sooner than 10 years. How bad are the cracks? hairline or large raised cracks?
Another dumb question.... Do you have a large tree near the driveway?
Old     (Laker1234)      Join Date: Mar 2010       01-11-2012, 9:50 AM Reply
No, water doesn't pool or freeze under the concrete and the cracks aren't raised or too large. I do have relef cuts and no large tree nearby. My best guess would be expansive soil. When the draught hit last year, in combination with a contrast of record rains in the las few months, I have noticed the cracks getting larger. I was hoping I could fill them in now to keep further water and freezing damage this winter. The last filler I put in just washed out.
