Old     (Tehanw215)      Join Date: Jul 2011       10-14-2011, 9:05 AM Reply
will the switch blade work on the sanger v215?
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       10-14-2011, 9:13 AM Reply
It should work on any boat. But you may need to beef up the transom.
Old    Mitch Mann (BoardCo)      Join Date: Mar 2010       10-14-2011, 9:33 AM Reply
A Sanger v215 should be able to support a Switchblade without much problems. We have not installed one on that particular boat, but I am familiar with Sanger boats and their hull design is strong enough to support one, no question. As long as it will fit below the swim deck and there aren't any problems with misc things such as exhaust placement or tim tab setups it should fit. If you have a Hydraulic trim tab it will probably have to be removed to install a Switchblade. One thing I do have to advise is that adding a Switchblade to your boat will void any remaining hull warranties - typically not a major concern, but something you should be aware of.
We have installed and worked on more Switchblades than anyone in the industry except for Switchblade themselves. Any of my guys here would be happy to help you with any questions you have. A Switchblade can be a phenominal investment for wakeboarding and surfing depending on your needs and what your goals are.
Good luck and keep shredding!
Mitch
BoardCo.com
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       10-14-2011, 11:33 AM Reply
Mitch I sent you an email.
Old    Harold Hemming (h20king)      Join Date: Dec 2009       10-14-2011, 1:52 PM Reply
The switchblade is amazing and should fit A v 215 with no problem.Manual or hydraulic trim tabs can be retained but if you have a single ram system you will need to change to a dual ram system .I retained my factory manual trim plate and adjuster arms by welding two studs to the switchblade mount.To retain a hydraulic trim system the switchblade mount would need a couple wholes drilled and taped in the mount .I did my own install it was easy and strait foreword but plan on a whole day for a clean install
Old    James Harold (jdjjamesz)      Join Date: Mar 2008       10-15-2011, 10:37 AM Reply
I think the hull is to low on that boat..
Old     (Tehanw215)      Join Date: Jul 2011       10-17-2011, 7:50 AM Reply
Hey James have you ever surfed behind the sanger v215? If so what do you think of the wave, and can it compare to the centurion waves?
Old    Mitch Mann (BoardCo)      Join Date: Mar 2010       10-18-2011, 9:21 AM Reply
Hey Duff,
Sorry I never got your email. You can send me a message to my account on wakeworld or email me at mitch@boardco.com. Thanks!
-Mitch at BoardCo
