Old    Tommy I (trio)      Join Date: Jan 2010       09-15-2011, 1:20 PM Reply
I have a set on Ronix Ones and I'm thinking about buying a new SS for the cable. Will my bindings work with there track system? Any Pros or Cons running my binding on the track system?
Old    Broc Schall (bschall)      Join Date: Jun 2007       09-15-2011, 4:49 PM Reply
My boy had LF bindings on a 2011 slingshot and he constantly had to tighten the bolts and his stance would constantly widen.. After he had problems with that the whole slider itself broke. Slingshot ended up sending him a 2012 board though and he claims the 2012 is alot stiffer so idk if it will have the same problem as last year.
Old    Ben Wilcox (benjaminp)      Join Date: Nov 2008       09-15-2011, 5:01 PM Reply
You might have bolt length issues, but in theory it should work. You can always trim down the bolts and use a bit of loctite if you have to.
Old    Jeff Seidenstricker (flydenrict)      Join Date: Nov 2009       09-16-2011, 1:00 PM Reply
+1 on the 2012 being alot better in the fast track department. That said, I ride 2010 Ronix Kais on my 2012 recoil and have no problem with bolt length or any sliding. I had them on my 2011 until i broke it too.
