Old    SeaDawg (seadawg)      Join Date: Jan 2006       09-12-2011, 5:51 PM Reply
My boat is a much happier place to be after I completed my last few projects. I've got a 2002 Calabria Pro-V, and my goal is to tweak and upgrade it enough that I'll never be desparate to get a brand new boat.
Project 1 was pretty easy: I've got two Optima batteries and moved them from the rear port locker in battery boxes, to the spot underneath the observer's seat. It's made a huge difference in storage for that rear locker - wish I'd done it sooner. Plus now, if I ever want to, I can actually put ballast back there. For the cable, I ended up using #2 welder's cable and it worked like a charm and didn't cost too much.
Project 2: since we're enjoying surfing more and more every summer, I decided to plumb in a ballast system instead of having to hassle with the filling my bags one at a time with one Tsunami all over the boat. So after buying the parts from Wakemakers, and a couple of support calls, I installed a single Jabsco Ballast Puppy that feeds a 750lb bag in my rear port locker, and also a 300lb tube bag what goes under the port side seats. The fill line Tees into the lower port of each bag, and each bag also has a vent line up high that Tees together, and goes out of a thru-hull I drilled above the water line on the port side, just outside of the observer compartment. That helps make sure it will never siphon water out. I had to add a ball-valve on the drain-line, btw, so that when the Jabsco is emptying, it doesn't suck air through the vent line via the smaller bag while finishing emptying the big one. That was an issue the first time I tested, but the valve fixed it.
I was nervous as heck to cut into the gel to install the switch, but instead decided to install it in the glove box. It was a relatively easy job with a dremel and cutting disc on the workbench.
The system takes about 10-11 minutes to fill, and luckily we haven't had any plumbing, electrical, or other issues yet. So, we've got those two bags, the stock 700 lb ballast, and I added a bow sac that probably fills to 400lb or so via Tsunami. With just a couple of people on board, I'm very happy with the normal-side wake.
Part three, the boat had a Clarion XMD2 deck when I bought it, and it just wasn't cutting it for me anymore. Solution, I upgraded to an Alpine CDA-118M marine receiver, and I also bought their waterproof RF remote at the same time. Gotta tell you, this deck kicks BUTT!! Dedicated RCA jacks for the subwoofer and interior speakers, plus it's got two speaker "zones". So, when we're pulling a rider, I've got the tower speakers cranking, without over-blasting the tunes in the boat. And with the RF remote, we can have the boat anchored and spiked at the beach, and we can control the sound system from 100 feet away. Also, like all new head units, it supports USB and iPod/iPhones right out of the box. I was using a radio transmitter for my iPod with the last system, and although it worked, it was . . .
We tested it out this weekend, and with the same 8 speakers, two amps, and a sub, the system sounded 100% better. For anyone shopping for a new head unit for your sound system, I highly recommend the Alpine.
Old    Kyle Henry (KyShredZ)      Join Date: Jan 2014       05-23-2014, 10:23 PM Reply
I am literally doing all of that to my boat right now! Plumbing fat sacs, replacing old clarion deck with newer one. I am also installing two underwater lights for surfing at night!
Old    Nate (norcalmalibu)      Join Date: Jun 2004       05-24-2014, 5:43 PM Reply
Sounds like a few good projects gave th boat a whole new attitude! We're are the pics
Old    Bill Amaral (soonerbilly)      Join Date: Jul 2013       05-27-2014, 6:45 AM Reply
Hey Sea....I have the same boat and did a 2 pump system. Do you get a clean wave out of it? I've only been out once since i installed it but not getting anything close to clean.
Old    SeaDawg (seadawg)      Join Date: Jan 2006       05-27-2014, 12:29 PM Reply
Hi there Bill - I actually love the wave we're getting with the setup right now. At first, I tried to run it with just the port-side ballast plus the fat sacs, but the wave wasn't great. Then we tried filling up both sides of the stock ballast plus the sacs, and everything is good. We surf with the Perfect Pass at about 10.5mph, and it's money.
Kyle, please post pics of the underwater lights when they're done!
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       05-27-2014, 12:39 PM Reply
It didn't happen if there aren't any pics.
Old    Bill Amaral (soonerbilly)      Join Date: Jul 2013       05-27-2014, 12:41 PM Reply
Sea...I dont have any weight up front. Do you have the adjustable trim tab?
Old    Matt (malibumatt)      Join Date: May 2006       05-27-2014, 12:44 PM Reply
Sea, Bill, first love the Calabria talk, second, you may have inspired me to preplumb the ballast as my wife complains with the over the side pump. Sea, did you just add a second battery in series or did you isolate with a switch? I am just now starting to research on this topic because I want mine out of the storage area as well. Only nice thing is a kitchen garbage can wedges nicely between the wall and the battery now.
Any pictures of the preplumb ballast?
Old    Bill Amaral (soonerbilly)      Join Date: Jul 2013       05-27-2014, 1:17 PM Reply
Hey Matt what do you want pics of. I have a few of my install. Didn't take pics of the holes though....should have.
Old    Matt (malibumatt)      Join Date: May 2006       05-30-2014, 2:37 PM Reply
just saw this from another thread. So did you follow the Malibu thread the same? 1 hole, Y, 2 pumps, no vent, drain back through the bottom?
Old    Bill Amaral (soonerbilly)      Join Date: Jul 2013       05-30-2014, 3:45 PM Reply
2 holes. directional y on each side. left side one direction to rear locker one to bag under seats right side one to rear locker one to a hose i keep in the infloor cooler section coiled up to reach anywhere in the boat i need. fly highs in the lockers with sumos in the boat so that i can fill more than one they have the locking link fill feature. ( they rarely leak out any water at all.)
Old    Matt (malibumatt)      Join Date: May 2006       05-30-2014, 4:33 PM Reply
thanks, I like the idea of the hose to fill anywhere in the boat, but I use the cooler in the floor so may need to plumb elsewhere. Where are you storing your cooler if you don't use the floor and the lockers are full of bags. Stupid Calabria seats sit too close to the floor to put one under.
Old    Bill Amaral (soonerbilly)      Join Date: Jul 2013       05-30-2014, 9:32 PM Reply
We usually just throw it wherever, usually only 4-6 of us, so not a big deal. We never used the infloor cooler area cause its kind of small.
