Old    TY-one-on (typhoon)      Join Date: Jul 2001       09-05-2011, 11:30 PM Reply
Is there some place to checking wiring or suggestions?
Thanks
Old    Cory D (cadunkle)      Join Date: Jul 2009       09-06-2011, 6:57 AM Reply
Check connections on the back of the tach. Wiggle the wires and see if it goes on and off, if so you have a bad connection or a break in a wire. If you're sure the tach has good power and ground, then check your signal wire to the coil or just run a new one (can do a temporary wire to test).
Old    TY-one-on (typhoon)      Join Date: Jul 2001       09-06-2011, 10:19 PM Reply
i'll give that a try.
thanks
Old    D H (dhcomp1)      Join Date: Mar 2010       09-06-2011, 10:26 PM Reply
The tach gets 3 wires.....ign power, ground, and signal.
Signal goes from the distributor if older....computer if newer.
What year, make, model, motor?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       09-07-2011, 8:18 AM Reply
2001 sanger v210
Old    Jay Wedsted (jbird)      Join Date: Jun 2011       09-07-2011, 5:26 PM Reply
Isn't there a module behind the dash that can be suspect, and costly?
Old    TY-one-on (typhoon)      Join Date: Jul 2001       09-08-2011, 8:14 AM Reply
i believe so but what makes it suspect is that it is intermittent.
