Old    vision (bobenglish)      Join Date: Mar 2008       09-08-2011, 1:05 PM Reply
I certainly hope the new X-star has a different hull, not just larger with more ballast compartments. The X-25 throws a great wake (I would even argue better than an X-star but that is personal preference) with significantly less ballast. A more efficient hull in the X-star would be nice.
The X-2 is also redesigned this year. Did the hull change or just the top?
Old    Jason (jason95gt)      Join Date: May 2006       09-08-2011, 1:45 PM Reply
The X-2 just got a new top deck. Not the hull.
Old    Luke Loewen (lalh20)      Join Date: Jun 2011       09-08-2011, 2:07 PM Reply
Not to mention, the weight of the deisel engine would just help the wake.
Old    Brett Yates (polarbill)      Join Date: Jun 2003       09-08-2011, 2:14 PM Reply
Originally Posted by wakecumberland View Post
I'm guessing this would do the trick
Specs:
Dimensions 36.57 x 29.84 x 31.02 inches (929 x 758 x 788 mm)
Cycle 4-Stroke Diesel
Max Power 235 kW @ 3800 RPM (320 HP)
Max Torque 685 ft-lbs @ 2500 RPM
Minimum Idle Speed 700 RPM
Full Throttle RPM 3800 RPM
Engine Capacity 254.10 cubic inches (4.164 liters)
Bore and Stroke 3.70" / 3.94" (94 / 100 mm)
Compression Ratio 17.5:1
Configuration In-line 6
Block and Head Material Cast-Iron Block / Aluminum Cylinder Head
Induction Type Turbocharged and inter-cooled circuit Dry air filter
Combustion Sequence 1-5-3-6-2-4
Dry Shipping Weight (engine only) 1014 lbs (460 kg)
Type of Injection Common Rail Direct Injection
Oil Capacity (with filter) 14.58 qts (13.8 liters)
Cooling Circuit Capacity 4.76 gal (18 liters)
Electric System Voltage 12Vdc negative ground
Alternator 110 amp
Daddy likey. I wonder who's engine they use when they make that diesel? Stereo guys will like diesels as well. It is easier and cheaper to upgrade to a 200+ amp alternator.
Old    Alan Slabaugh (alans)      Join Date: Aug 2005       09-08-2011, 2:26 PM Reply
Here is my guess.
http://www.cumminsdieselspecs.com/v6_cummins.html
Old    Mase (superair502)      Join Date: Mar 2010       09-08-2011, 2:28 PM Reply
Don't deisels spit unused gas into the air? In this case water?How do they work in a boat cuz I know bigger boats have them
Old    Mase (superair502)      Join Date: Mar 2010       09-08-2011, 2:35 PM Reply
A cvt would be perfect for a wakeboat. My lady has a altima coupe with one and it's awesome when you are accelerating because there is no shifts just a long progressive one. It takes getting used to but it's pretty cool. I though the problem with cvt's however was the lack to handle huge power and loads. Seems that would be a problem in a wake boat
Old    Brett Yates (polarbill)      Join Date: Jun 2003       09-08-2011, 2:36 PM Reply
Originally Posted by alans View Post
I just found that the Yanmar 6LP series has a 315hp 254CI version. The 6LP also has a max rpm of 3800. Same engine with fancy Ilmor dressing? That is my guess,
Old    Luke Loewen (lalh20)      Join Date: Jun 2011       09-08-2011, 2:38 PM Reply
It's not really unused gas, it's more sediment that's a result of a less efficient burn (I hope I have that right). Someone more familiar with diesels can explain but most of today's diesel engines, despite the looks of exhaust are relatively clean to the environment vs competing gasoline engines.
Another great point is you don't die from carbon monoxide poisoning from diesels, you can get sick, but it's not a killer like gasoline engines. MAJOR PLUS!
Old    Tdc_worm C (tdc_worm)      Join Date: Sep 2002       09-08-2011, 2:47 PM Reply
Originally Posted by cboom12 View Post
ummm. no they r not. They put a diesel in the x80 a couple years ago and there are several marine diesel manufacturers out there. They are stuck with ilmor no more than they were stuck with indmar. The boat manufacturer decides who motor they decide to use. I suspect that the reason for not putting a diesel in the star is actually cost, surprisingly. I believe the vw motor they had a couple years back was a shade under 30k for the option. That being said they either pass that on to the consumer making the boat even more expensive or lose some of their margin. The other thing i have heard and this could be totally off is that with all the emissions standers the EPA is placing on diesels it may not be all that easy to adapt for the application.
i think you actually just agreed with me. MC neither makes nor marinizes engines. they source them from a marinizer...and they are limited to the marinizers at hand (not just illmoor, indmar, etc).
i agree with you...i suspect the reason we dont see diesels in light boats is twofold: 1) cost and 2) most inland lakes do not have on the water diesel pumps.
to put it in perspective, if Ford, GM and Dodge have bailed on the idea of a light duty diesel for 1/2 ton trucks, of which they will sell over 1m annually, then i suspect it is not cost effective to pursue a low volume diesel for boats (i know, i know, it is not apples to apples).
Old    Brett Treiber (pc_sledge)      Join Date: Jan 2006       09-08-2011, 2:51 PM Reply
Hell ya, about time a major player in wakeboats introduces a diesel...in my opinion there really is no cons to the diesel engine option for wakeboats.
Old    Mikeski (mikeski)      Join Date: Aug 2003       09-08-2011, 2:52 PM Reply
that motor would probably work quite well. to achieve equivalent prop RPMs you would need to regear the V drive from 1.5-1 down to 1.15-1 so the torque difference would not be quite as significant as initial numbers lead you to believe. The PCM ZR6 motor delivers 600ftlbs of torque to a prop through a 1.5-1 gear reduction. The diesel specd above would deliver 730ft lbs of torque through a 1.15-1 trans spinning the prop at the exact same speed. That's an increase of 20% more power to the prop. Weight is only 60 lbs more.
Old    Jason (jason95gt)      Join Date: May 2006       09-08-2011, 2:57 PM Reply
The lack of Diesel gas pumps is one main reason along with top end speed. Granted wakeboats don't need to go over 28, but no one wants that to be your top speed. Since they only spin to 3800 rpms they have to change the transmission and that might be an issue to.
Old    Jason Smith (snowslider76)      Join Date: Mar 2002       09-08-2011, 2:57 PM Reply
I'd like to see this under my Christmas tree.
All this hype better lead up to something ungodly awesome!
Old    Johnny (johnny_defacto)      Join Date: Sep 2006       09-08-2011, 3:21 PM Reply
I am very impressed that MC was able to keep this under wraps until the show. That is tough thing to do when so many hands have been involved with designing, building and testing this boat, and when all those hands have camera phones, facebook, twitter, ww....
good job MC.
I am excited to see it, and more excited to start reading all the mastercraft bashing that will go down immediately after it is revealed
Old    vision (bobenglish)      Join Date: Mar 2008       09-08-2011, 3:36 PM Reply
Diesel and a CVT would be awesome. But I suspect it would add 20K to place a diesel with a CVT in a boat over the current gas engine and std V drive.
Or an integrated electric motor that only assisted the gasoline engine during the first 30 seconds of load to help get the rider out of the water and the boat to plane. Since electric motors have instant torque, this would really be helpful. Make the assist user switchable so when not ballasted the electric motor could be set not to kick in. If you only were using the electric motor a few minutes of every hour, the batteries should last most of the day.
Old    Matt (duckguy)      Join Date: Jul 2006       09-08-2011, 3:38 PM Reply
Your right about that one Johnny. Whah it's to expensive, Mastercraft has lost their way. Whah the tower sways, no it's ugly, no it dosent fold easy, no it' fold's to easy the power part will fail. Whah To much bling. Whah Whah Whah
I bet it's cool as hell!
Old    Tdc_worm C (tdc_worm)      Join Date: Sep 2002       09-08-2011, 3:41 PM Reply
just so we are clear here, the engine does not provide more torque, it is the gear reduction of the transmission that provides the torque. before PCM gets that engine to marinize it, GM specs it at 400 lb/ft @ 4k rpm. the 1.5:1 transmission makes the propshaft torque approx 600 lb/ft (not including the parasitic loss to the transmission and v drive friction/drag). ref: http://www.gmpowertrain.com/Librarie...rine.sflb.ashx
the one thing we are not taking in to consideration is overall "gearing" which is affected by the prop selection. loading down a boat is similar to putting bigger tires on a truck in terms of load placed on the drivetrain...to return the truck to its optimal operating range, lower gears (numerically higher) often have to be swapped in. changing prop pitch is similar to changing differential gears. if you run the same 1.5:1 transmission in the diesel boat, you could run a higher pitch prop to regain your optimal operating range.
Old    Johnny (johnny_defacto)      Join Date: Sep 2006       09-08-2011, 3:43 PM Reply
saw this picture of the transom of the xstar and thought how nicely an outdrive would bolt to it....
Old    Jason Smith (snowslider76)      Join Date: Mar 2002       09-08-2011, 3:53 PM Reply
This idea of the current Xstar hull being an I/O wouldn't that be the "R" in R&D, research?
I would have expected it to go something like this, an R&D engineer at MC studying all kinds of hulls and what type of wake they produce, finds one that is close to the type they are looking to produce. Brings it to his design team and says guys look at this how can we make it an inboard? They spec it up. Pretty sure that's how R&D works. Doesn't always start from an idea on a napkin.
Old    Alan Slabaugh (alans)      Join Date: Aug 2005       09-08-2011, 4:30 PM Reply
Nope, I don't buy it. Most stern drives have a recessed portion where the out drive fits. The X-Star would make a pretty terrible handling and planing stern drive.
Old    Jason (jason95gt)      Join Date: May 2006       09-08-2011, 4:30 PM Reply
I had heard a rumor when the 03 Star came out that it was actually a Cobalt mold that just didn't work for I/O's and they went from there.
Old    Johnny (johnny_defacto)      Join Date: Sep 2006       09-08-2011, 4:40 PM Reply
yep jason, thats about what I heard. Maybe its just a widely spread rumor made up by all the MC haters, or CC, BU, and SC salesmen.
If its true, it would be very funny...
Old    Joe (ilikebeaverandboats)      Join Date: Jul 2007       09-08-2011, 4:45 PM Reply
idk how long I've been saying this lol but for once someone agrees. CVT and a diesel would be a match made in heaven, it'd be efficient, and provide plenty of torque. Thats all we need, not 600 hp gassers chugging fuel. we don't need the horse power we need the torque!!!
Old    Jon Hunter (hunter660)      Join Date: Aug 2007       09-08-2011, 4:46 PM Reply
What does it matter if the current X-Star hull started as an I/O or not?
Old    A-dub (behindtheboat)      Join Date: Aug 2006       09-08-2011, 6:14 PM Reply
I believe it was former Cobalt engineers were part of the R&D and design of the Xstar.
Old    Chase Tillett (tn_rider)      Join Date: Dec 2009       09-08-2011, 9:15 PM Reply
Looks like some of you were correct in your predictions according to the pic MC just posted on Facebook. Wrap with all the workers and riders names on it.
Old    Tre (tre)      Join Date: Jul 2002       09-09-2011, 7:54 AM Reply
7 more minutes.
Old    Jason (jason95gt)      Join Date: May 2006       09-09-2011, 7:59 AM Reply
Action Watersports has a live feed on there facebook page.
Old    J D (jeff_mn)      Join Date: Jul 2009       09-09-2011, 7:59 AM Reply
post it here.
Old    J D (jeff_mn)      Join Date: Jul 2009       09-09-2011, 8:02 AM Reply
http://www.youtube.com/watch?v=jAaWePnOwew
Old    Ben (kamighazi)      Join Date: Nov 2008       09-09-2011, 8:04 AM Reply
Old    J D (jeff_mn)      Join Date: Jul 2009       09-09-2011, 8:05 AM Reply
beautiful
Old    Jason (jason95gt)      Join Date: May 2006       09-09-2011, 8:05 AM Reply
The youtube video is SICK!
Old    Shawn B (ShawnB)      Join Date: Oct 2010       09-09-2011, 8:07 AM Reply
First impressions (not always the best when talking about boats)
* like the bow seating and walkthrough seating
* like the new board racks
* don't care for the rear-facing seats
* gauges are beyond bling but I like them
* need to see the wake/hull/etc to pass final judgement
Old    Chattwake (chattwake)      Join Date: Jan 2010       09-09-2011, 8:10 AM Reply
Crazy. Way over the top. Definitely pushing the envelope. Can't wait to see the wake pics!
Old     (AllianceBJJ)      Join Date: Mar 2011       09-09-2011, 8:10 AM Reply
So far it looks like my source was pretty much right in what they told me....Not quite sure how I feel about it yet, will have to wait for more pics/video/details to come out....
Old    Mase (superair502)      Join Date: Mar 2010       09-09-2011, 8:12 AM Reply
If rusty is saying the wake is so big that is definitely saying something after seeing how he weights boats!!
Old    Ian Brown (wakereviews)      Join Date: Sep 2006       09-09-2011, 8:13 AM Reply
Old    Ian Brown (wakereviews)      Join Date: Sep 2006       09-09-2011, 8:14 AM Reply
Looks pretty bad a** to me!!!!
Old    Jason (jason95gt)      Join Date: May 2006       09-09-2011, 8:16 AM Reply
It is about time MC has more rear facing seats and a much better idea then Nautiques stadium seating or Supras. Insane.
Old     (MrPeepers)      Join Date: Aug 2011       09-09-2011, 8:16 AM Reply
Looks amazing, but why do I feel like all these new boats are going to be impossible to sell in 10 years? What happens when the electronics fail?
Don't get me wrong, that dash is badass, but I am just thinking from MY perspective. My thoughts are not limited to MC and aren't even an issue that the manufacturers should care about.
I will only ever buy used boats, so in 10 years when I can actually afford this xstar, what kind of problems am I going to have trying to keep it going? If the electronics fail will i even be able to work around the problem? All electronics fail eventually. Add computer programs into the mix and things could get frustrating very quickly.
Sick boat though. I can't wait to see the wake.
Old    Chattwake (chattwake)      Join Date: Jan 2010       09-09-2011, 8:17 AM Reply
Time to start buying those power ball tickets.
Old    David Curtis (davez71)      Join Date: Oct 2007       09-09-2011, 8:17 AM Reply
This was the picture i saw on facebook. Pretty Sweet if you ask me
Old    David Curtis (davez71)      Join Date: Oct 2007       09-09-2011, 8:19 AM Reply
Another
Old    Matt (MattieK27)      Join Date: Mar 2010       09-09-2011, 8:19 AM Reply
It might produce the biggest wake anyone has ever seen, but the styling is definately not going to win me over. Too dramatic for me considering its a 24' boat. Many of the style elements remind me of my parents boat. ( http://www.searay.com/Page.aspx/page...Sundancer.aspx )
I like the functionality of the interior though...
Old    Chattwake (chattwake)      Join Date: Jan 2010       09-09-2011, 8:20 AM Reply
I want to see a picture of the transom area. Looks crazy!
Old    Chattwake (chattwake)      Join Date: Jan 2010       09-09-2011, 8:21 AM Reply
One other question. Does the tower look low to anyone else?
Old    jaubrey (jaubrey)      Join Date: Feb 2003       09-09-2011, 8:22 AM Reply
I love everything except that ugly a$$ tower. The lines just dont fit the boat. Great job MC on the rest of the boat. They really stepped up the game!
Old    Bruizza (bruizza)      Join Date: May 2009       09-09-2011, 8:24 AM Reply
That thing is sick. I can't wait to see the wake.
Old    Jay (ironj32)      Join Date: Jan 2007       09-09-2011, 1:00 PM Reply
Old    TN22            09-09-2011, 1:05 PM Reply
Beautiful interior and appears to be very functional. The dash is also pretty awesome and over the top. However, I do not like how the rubrail dips near the stern. I know it's different etc, but I just don't like the look of that. Anybody heard a price on this thing? I'm guessing it will be pushing 120K easy
Old    Javier R (Jrod)      Join Date: Aug 2010       09-09-2011, 1:13 PM Reply
http://www.youtube.com/watch?v=S6hkaHm7sQA
Old    Brett Treiber (pc_sledge)      Join Date: Jan 2006       09-09-2011, 1:20 PM Reply
Incredible. That interior looks so well thought out and functional. Exterior looks pretty crazy but dig the video of it in the water. Can't wait to check out the wake. Most def a new bar for other manufacturers to aim at. Love it.
Old    readyaimfire            09-09-2011, 1:21 PM Reply
I need to see the wake... Styling is questionable
Old    Brett Yates (polarbill)      Join Date: Jun 2003       09-09-2011, 1:22 PM Reply
Hahahahaha. That ugly boat looks like the Homer Simpson designed car. Just horrible. I will admit they put some effort and pulled off the front and rear facing seats. Definately better then anybody else's versions. It looks like a 71 boat tail buick riviera with that big rounded out rear area. What in the hell are vent things on the vdrive sunpads? Are those head rests for the people in the rear seats? It looks like a cross between riviera and an eliminator with an F16 cockpit. power dash is completely stupid. Why would I ever want it closed? Let me guess, 150-200k? Good luck with that. It also kind of looks like a early 90's centurion falcon from the side. They tried the stupid seat for the rider to put on a board like sanger. There is another fail. It is definetely pushing the envelope but doing it in a very ugly over the top way. I basically like nothing about it other then the multifunction seats.
Sorry, I just wanted to be the first to truely hate on it. I really am starting to dislike everything Mastercraft is doing and stands for.
Old    Johnny Neves (johnny_jr)      Join Date: Mar 2006       09-09-2011, 1:24 PM Reply
I'm not a MC guy at all, but I must say that this boat has some serious mount of engineering and innovation that has gone into it. WOW..... still amazed at all the little things that can be done with the seating configuration alone.
Well done MC, well done!
Old    Erik (kinger)      Join Date: Jun 2007       09-09-2011, 1:27 PM Reply
I think its pretty bad, looks like a Transformer
Old    Ryan Glazier (Glaze08)      Join Date: Jul 2011       09-09-2011, 1:59 PM Reply
Looks ****ing boss to me. Innovation everywhere.
HATE THE PRICE SO MUCH THOUGH.
Old    David Williams (wakeworld)      Join Date: Jan 1997       09-09-2011, 2:45 PM Reply
Here are some pics we took last night. I'm adding some more tonight.
http://www.wakeworld.com/news/latest...surf-expo.html
Old    Mase (superair502)      Join Date: Mar 2010       09-09-2011, 3:16 PM Reply
Why don't u guys just watch that video if you want to see the wake?? It looks freaking massive tho!!! U can tell Steele didn't expect that much kick on the tantrum an tried to slow it down
Old    Jamie Corvin (Bumpass1)      Join Date: Oct 2010       09-09-2011, 4:04 PM Reply
74 gallon fuel tank = high interest loans for fill ups
Old    Brian (99sportster)      Join Date: Oct 2005       09-09-2011, 6:31 PM Reply
The wake looked huge in the video, but the opposite side was washed out.
Old    Andy Graham (ottog1979)      Join Date: Apr 2007       09-10-2011, 9:46 AM Reply
Polar Bill, It also looks a bit "low profile". Gotta worry about safety like those Sangers.
Old    Brett Yates (polarbill)      Join Date: Jun 2003       09-10-2011, 9:55 AM Reply
I think it actually does look pretty low profile for a 24 foot boat. I think they have that thing slammed though. I wouldn't be surprised if they had 4000+ pounds of ballast in that thing. It sure seems like it is designed for a very small group. It doesn't really look like a good family boat, it has a similar looking hull to the current xstar so it probably sucks at surfing, it is only going to be good at wakeboarding, it is huge and heavy so that is going to limit it's buyers, etc... I guess if you want the biggest and best wakeboard wake and money is no option it is a viable option. I just don't see the true hardcore riders being the one's who want to drop 125k or so on a wakeboat. You can get 95% of the wake out of a SAN230, 23LSV, 247lsv for 25-35k less or you can get an A22 or TWB23 for less then half the price and you still get 95% of the wake and 75%+ of the room. It truely only makes sense to someone who has more money then they know what to do with.
Oh and if that was a shot at me for bringing that up in the cali boat builder thread, I don't mind the low profile myself too much but 90% of the potential buyers are going to be concerned with that.
Old    Fred (fredlap)      Join Date: Jul 2008       09-10-2011, 10:35 AM Reply
For ME, it looks weird! It's all about bling bling. Top interior with awesome new idea, but we all know what it means.... more than too much $$$. When I ride, I don'y give a sh ! t about how the electric gage works (like a light on a old Ford Probe), how the seating is or how the tour collaps. I only care about the wake. Whatever all the riders said, what I see at 0:25 on this vid is a washy wake like 5 feet before the rider so.... I'm not in for this one! Anyway, I'm not a Mastercraft guy (except for the X-25). Since I saw the wake (on a 2010) with the plug an play, I'm not impressed at all. Anyway, the only boat who really impress me each time I saw the wake is the Epic 23V and I rinde behind each w-e! ; ) lol
Old    np3 (ponder86)      Join Date: Mar 2008       09-10-2011, 10:42 AM Reply
I think the wake will be awesome, you know they have that boat loaded. If you watch practically any video of pros behind w/e it may be MC, Nautique, or Malibu the other side of the wake is usually washed out b/c of how much weight they put in the boats. But, it always clears up when the come in and hit it.
I think this Star will surf better than the last one as well because the way they designed the ballast tanks in the back to run up the side of the boat. It should cause it to sit lower and produce a better wave.
Old    Fred (fredlap)      Join Date: Jul 2008       09-10-2011, 10:46 AM Reply
Next things in the X-Star ;
-electric mirror
-heating seats
-sun cream distributor
-microwave
Old    Fred (fredlap)      Join Date: Jul 2008       09-10-2011, 10:48 AM Reply
the vid I was talking about... sorry!
Old    Fred (fredlap)      Join Date: Jul 2008       09-10-2011, 10:50 AM Reply
sorry np3 but it's not on the other side!
Old    DC (durty_curt)      Join Date: Apr 2008       09-10-2011, 11:48 AM Reply
24 ft long?! And that's not including the platform?!?! That things a beast! And I thought the 23 ft wakeboats were pushing the limit. They should keep the original Xstar in the line up and just name this thing the Death Star! ! Hahaha
Old    np3 (ponder86)      Join Date: Mar 2008       09-10-2011, 12:19 PM Reply
Fred, I see what you are talking about now. It could also be they didn't have the speed dialed. In some of the other shots it appears like it is cleaned up nicely. Cannot be sure until it's in person though.
Old    Timmy! (timmyb)      Join Date: Apr 2007       09-10-2011, 12:45 PM Reply
The lines in the side of the hull at the top make it look like a blue whale or something...not my thing but I like the functionality of the seats, pretty slick.
Old    d_rock (d_rock)      Join Date: Jun 2003       09-10-2011, 1:42 PM Reply
I really think MC nailed it with the original pickle fork 04- ? whenever. I remember hating the picklefork front end at first but it has grown on me. The tower design really fit with the boat and the price wasnt too outrageous. The CIE guys had one of the best looking ones ive ever seen. I had a little bit of boat envy, to say the least. But I will never have boat envy for the newest version. The hull design/flare on the stern is awful. And that tower just is plain ugly to me. When the only good thing to come out of a boat is the seat design, I just gotta wonder who MC uses for focus groups on the marketing side of things. Maybe Im just not who they are targeting. To each their own I guess.
Old    Johnny (johnny_defacto)      Join Date: Sep 2006       09-10-2011, 3:03 PM Reply
yeah np3 and fred. I noticed that too on the tantrum. he hits that wake with terrible wash. I am guessing that they were dialing the speed cuz in the shots that follow the wake was really clean on the side they were hitting. The wake looks amazing so far. I wonder how much weight was in it. You can see a big 500+ bag in the walk through in one of the shots.
+2 for deathstar.. lol
Old    "G" (grant_west)      Join Date: Jun 2005       09-10-2011, 3:35 PM Reply
WOW the Interior is Awesome. The Shape down the side I like it! The curved Front window. Im sure there is way more detail to this thing in person then in what the video show'd
Has the price for this thing been published. My guess is your gonna be in the $150 and UP range
Then watch all the Boat critic's come out of the wood work, LOL
This thing is the Bugatti Veron of the wake comunity,
I agree with all the touch and LCD screen's that control everything thats the only thing that worry's me down the line. Simple switches and Gauges that do the job and dont break are the ticket
Old    Timmy! (timmyb)      Join Date: Apr 2007       09-10-2011, 5:53 PM Reply
No silly, that boosts the ballast up by another 500lbs! Kind of like the Bu 247's that have the 90 gallon, just more ballast.
Old    Austin (austin)      Join Date: Apr 2010       09-10-2011, 6:30 PM Reply
If you have to ask...
Old    "G" (grant_west)      Join Date: Jun 2005       09-10-2011, 7:07 PM Reply
Yea I guess your Right! What a stupid question. Please forgive me! LOL
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       09-10-2011, 7:40 PM Reply
The X45 has a 90 gallon tank too. I think it is awesome to have a big gas tank. Never have to worry about running out of gas. I can go constantly for at least 2 days without wondering if I am going to run out.
