Old     (nitrousbird)      Join Date: Sep 2008       08-29-2011, 11:27 PM Reply
I wanted the Fly High pump setup (as my current pump is cracked/leaking and I'm not ready to do a full auto-ballast until this winter), but thought $100 was a bit steep for what it was. I ended up piecing together everything to make the same setup (with better hose/clamps) for less money.
Pump ($32.48):
http://www.amazon.com/Attwood-Corpor...4684276&sr=8-1
Power Cord ($7.01):
http://www.amazon.com/RoadPro-RP-255...684169&sr=1-87
Hose (9') ($13.41):
http://www.wakemakers.com/mastercraft-ballast-hose.html
Clamps (2) ($1.98):
http://www.wakemakers.com/1-inch-hose-clamp.html
Pump Quick Disconnect ($6.99):
http://www.wakemakers.com/fly-high-p...ting-w734.html
Hose Quick Disconnect ($5.99):
http://www.wakemakers.com/fly-high-p...ting-w738.html
Order the Amazon stuff together and all shipping is free. Shipping for the Wakemakers stuff was $5.95. Grand total: $73.81
Saves you $26 over buying the Fly High Pump package, and you get a much nicer hose in the process, and better hose clamps. I purchased all of this minus the power cord, as I had old 12V power plugs and wire laying around I used instead, which made this even less costly to put together.
Putting it together is really easy. The Attwood pump comes with more threads than you need, so you can either keep it long or simply saw off the end and make it as short as you want.
For the wiring, just cut off the end, strip the wires, solder to the Atwood pump wires and heat shrink it. Or you could butt connector and electrical tape it as well, but that's not as soild / professional as I would want for something I'm throwing in the water a lot.
I figured this might be useful for those that don't mind a few minutes of wiring to save themselves some money.
Old    Adam R (wakecumberland)      Join Date: Oct 2007       08-30-2011, 6:59 AM Reply
Good Job! Thanks
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       08-30-2011, 7:01 AM Reply
Great job. You better be carful with those stainless clamps. They are not to friendly around gelcoat, vinyl and fat sacs
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       08-30-2011, 7:52 AM Reply
or fingers! I've sliced my fingers open every time I've messed with my heater, or winterized the boat, or...
Old    Anthonyv911 (tonyv420)      Join Date: Jul 2007       08-30-2011, 8:14 AM Reply
Sweet!! Thanks Shawndoggy, I'm on it! gonna make me one of those for half price! Gotta save money for fuel these days man! know what I mean?
Old    Timmy! (timmyb)      Join Date: Apr 2007       08-30-2011, 8:38 AM Reply
I think mine was only $80 through my local dealer. He discounts everything for people that have bought a boat from them.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       08-30-2011, 8:42 AM Reply
you mean nitrousbird?
Old    Jeff D (Jeff)      Join Date: May 2010       08-30-2011, 10:35 AM Reply
I did the same thing accept I used the "premium ballast hose" because 1) it coils up better 2) you can see into it to make sure things are pumping. Also, I used the crimp on clamps which have no sharp edges. The end result is better than the off the shelf fly high pump because the cheap vinyl hose on those kinks and doesn't roll up well.
Old    Greg Bodor (gti2lo)      Join Date: Nov 2005       09-01-2011, 9:44 AM Reply
thank you for the links!
