Old     (Tehanw215)      Join Date: Jul 2011       08-15-2011, 3:58 PM Reply
my speedo on my 05 v215 sanger is sticking a little bit. any input on fix?
Old     (humboldt9)      Join Date: Jun 2004       08-15-2011, 7:51 PM Reply
I'll be interested if you can get this fixed. I have a V210 with the same issue. If you search the board on this topic there are a lot of reponses that will point you toward the Medallion instrument under your dash. It basically controls all of the gauges on your boat. I've hesitated dropping the coin on a new one in hopes of finding an easier fix.
Old     (Tehanw215)      Join Date: Jul 2011       08-16-2011, 9:32 PM Reply
thanx will check it out. U from humboldt?
Old     (Tehanw215)      Join Date: Jul 2011       08-19-2011, 12:47 PM Reply
cleaned my speedo sensors on back of boat. Found gunk in the holes on each sensor. Pretty sure that will fix prob.
Old     (humboldt9)      Join Date: Jun 2004       08-19-2011, 7:08 PM Reply
No, not from Humboldt but was recruited to play soccer at HSU spent three years there and realized I couldn't take the rain anymore and then moved back home to SoCal. Glad you got your gauges back in order, what did you use to clean out the sensors?
Old     (Tehanw215)      Join Date: Jul 2011       08-20-2011, 9:37 AM Reply
yep lots of rain here. i used a sewing needle
