Old     (boarder82)      Join Date: Jun 2009       07-16-2011, 4:53 AM Reply
We have recently been having a problem with the engine temp gauge on our 2003 Malibu VLX. Up until about a week ago the gauge had always read correctly, right at 160. But last week the gauge started to settle in at about 100-120 degrees when warm, and it never got close to 160. Have any of you guys seen this before? Is the gauge going bad? Or is it something else?
I hate not knowing what actual engine temp is!
Thanks in advance for your help.
Old     (shawndoggy)      Join Date: Nov 2009       07-16-2011, 5:39 AM Reply
Is there any chance that your thermostat is stuck open and the boat is running cool?
Old     (helinut)      Join Date: Apr 2007       07-18-2011, 9:00 AM Reply
Yup, sounds like a stuck thermostat.
Old     (deltawake)      Join Date: Sep 2004       07-18-2011, 9:18 AM Reply
We had the same issue and it was definitely a stuck thermostat. Your fuel consumption is probably significantly higher also, as the engine does not run as efficiently.
