Old     (DrA)      Join Date: Jul 2011       07-10-2011, 4:13 PM Reply
hey. looking at a 2001 moomba outback that i can't tell from the pics if the boat is an outback or outback LS (especially since i don't know what to look for). anyone know how i could easily determine if the boat is the LS version? nada says the outback has a 3" shorter beam and lower value... i guess i can take my tape measure when i go look at the boat. thanks for your help!
looking to get into wakeboarding and skiing on a budget. appreciate it.
doc
Old    nwwakerider            07-10-2011, 5:33 PM Reply
Post the pics on here. I'm sure someone can tell from the photos.
Old     (stuey)      Join Date: Dec 2004       07-11-2011, 1:28 PM Reply
I used to have an outback LS... 2003 so not sure if 01 is the same. But in 03 the LS had a ski locker (which was good for ballast) and the regular did not.. also the LS had a single rear sundeck that folded to toward the bow while the regular was split in two and folded towards the gunnels.
If you want to wakeboard then stay away from the regular.. i can't remember the reasoning but the hull was geared way more towards skiiing while the LS had a more crossover hull that could generate a good wake with enough ballast.
Good luck with it..post some pics and I can try and help
