Old    Jon (jon4pres)      Join Date: May 2004       07-03-2011, 5:34 PM Reply
We just built and installed our new dock. Looks and works great but kind of just blends in with everyone elses on the water. I want to put green led strip lighting around it to match the green neon lighting that is on the front of the house.
I know there are lots of led experts on here so here is my question.
I found a enough led lights on ebay http://cgi.ebay.com/5x-5M-500CM-Gree...#ht_3741wt_962 to do what I want but am not sure if they will fit together end to end.
Will they?
How do you do it?
Can one 110 to 12v converter run 150ft of leds?
Is there a better place to buy them.
Thanks
Old    Nate Ramsey (V237TX_Nate)      Join Date: Jun 2011       07-04-2011, 9:52 AM Reply
Not sure about dock lights, but when I built the deck at my house I used a 110 to 12V converter to power all my lights (about 30 separate lights) I did make a 30 amp circut of my main breaker, then ran that to the converter. You just have to add up the wattage of all the lights and ensure the converter you get can put out that much (I would say a little more so it doesnt trip the breaker) Anyways I bought the converter at homedepot. Good Luck
Old     (moto817)      Join Date: Jan 2011       07-06-2011, 9:16 AM Reply
Check out Superbrightleds.com there is alot of useful information on here.
Old    John Bauer (jonyb)      Join Date: Nov 2008       07-08-2011, 3:56 AM Reply
http://www.wildcatlighting.com/
Old    Jeff (jroyal)      Join Date: Jan 2003       07-08-2011, 8:11 AM Reply
Got any pics of the house with the green LEDs on it? Curious to what that looks like. thanks.
Old    Erik Forinash (4Nash)      Join Date: May 2011       07-08-2011, 1:15 PM Reply
www.oznium.com
Old    Jack Flap (flapjack)      Join Date: Feb 2010       07-08-2011, 2:00 PM Reply
the add says 0.4A / meter. 150' = 46m. 46 * 0.4 = 18.4A total.
18.4A * 12V = 220W
The copper in the ribbon cable is thin. Over ~5M, you will notice a voltage drop and the light brightness will vary, so you will not want to daisy chain them all together. They could share a power source.
