Old    eric schaefer (ess3489)      Join Date: May 2009       06-28-2011, 4:12 PM Reply
putting a set of fusion tower speakers
Features:
Diamond Audio CM3 Series components: CM361 + M351i
Handles 200 watts RMS per side
Asymmetrical Aluminum Manufacturing Process (AAMP)
Chrome billet tower mounts with carbon rubber plastic inserts
F-Lock anti-rotating mount
Chrome finish
1 year limited warranty
Weight: 13 lbs per unit
Except in cases of warranty issues, sales on racks and speakers are final.
looking for a good amp to power these, since each speakers is 200 watts rms should i be looking for a two channel amp that will give each side 200 watts?
i was thinking about the hifonics HFi100.2 400w amp will this amp work? and any suggestions for an amp in around the same price range?
Old    Scott (pdqwrx)      Join Date: Jul 2007       06-30-2011, 12:42 AM Reply
A 4 channel would let you get a little more sound out of the 6" set because you could adjust the gains and crossover points to maximize the larger driver. You would also have a pretty standard 4 ohm load per channel. I would suggest an ARC Audio 300/4 or a Wet Sounds SYN 4. Both amps would work extremely well and give you plenty of un-distorted output. At 90 watts or so per channel you'll be rocking.... There are tons of posts on these amps if you want more opinions, just hit the search button....
Scott
