Old    Jon (jon4pres)      Join Date: May 2004       06-11-2011, 9:54 PM Reply
Has anyone ever added inserts to a board. I have an old slingshot board with the 4 hole biniding system and would like to put some other bindings one it that do not attach that way.
Anyone??
Old    Mark Griffin (cheesydog)      Join Date: Mar 2009       06-12-2011, 10:38 PM Reply
no idea how you would do it but Id love to see the result, good luck with it
Old    gangstar (joe_crawley)      Join Date: Jan 2007       06-12-2011, 10:44 PM Reply
should actually work pretty well on a wood cored board
Drill with a ~C drill bit first where you want the insert. Then open the hole with a 17/64" drill bit so it is to the proper size. Use some drill bit stops to ensure you don't drill through the board. Then get a 1/4"-20 STI tap and helicoil, tap the hole, install the helicoil, and there you have it, a brand new insert. I will try this on my busted ass severance this week or next and let you know how it goes. Maybe I will take some video.
Old    gangstar (joe_crawley)      Join Date: Jan 2007       06-12-2011, 10:47 PM Reply
forgot to add you will need a bottoming tap, not a plug tap
Old    Jon (jon4pres)      Join Date: May 2004       06-13-2011, 8:28 PM Reply
Awesome. I will wait on your results before I screw up my good board.
