Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-10-2011, 1:24 PM Reply
I have a 2011 recoil i love but im sellin the vandalls i use for them and i wana pair of new boots that will work with the slingshot strata line and work on a regular 6-hole board. any suggestions? maybe hyperlite system or any good bindings
Old    Small Light (stephan)      Join Date: Nov 2002       06-10-2011, 2:00 PM Reply
Don't all bindings work with the Strata system?
Old    Shredtastic (seth)      Join Date: Sep 2002       06-10-2011, 4:18 PM Reply
Yes, I do believe the possibilities are endless.
Old    Jason (jason95gt)      Join Date: May 2006       06-11-2011, 9:51 AM Reply
They all will work with the Strata, but I am not sure if Slingshot will warranty a defective board if anything but the RAD boots are mounted on it. That is the case with Hyperlite. If you don't use their boots they will NOT warranty the board.
Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-12-2011, 10:33 AM Reply
well liquid force boots didnt fit my board at all so i was wondering
Old    Ben Wilcox (benjaminp)      Join Date: Nov 2008       06-12-2011, 1:21 PM Reply
In what way did they not fit? I really thought everything would fit on a track system.
Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-12-2011, 7:36 PM Reply
they would be lose as in i couldnt tighten down the top bolt to the bindings for a snug fit on my board. i honestly do not think u can use any other boot but the Rads or any boot by slingshot or company
Old    Ben Wilcox (benjaminp)      Join Date: Nov 2008       06-12-2011, 7:38 PM Reply
So they fit, but your bolts were too long. Toss a couple washers on top and you're good to go.
Old    gangstar (joe_crawley)      Join Date: Jan 2007       06-12-2011, 8:02 PM Reply
any boots work with the slingshot system
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       06-12-2011, 8:07 PM Reply
dito.
you can run into this kind of problem with loosness mixing any brands of boots even with traditional inserts. insert depth and bolt length vary brand to brand. washers is the way to go
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       06-12-2011, 8:08 PM Reply
there are the slingshot Options boots too.
Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-12-2011, 8:26 PM Reply
can anyone try to put the hyperlite systems on a 2011 slingshot for me cause thats what i really want
Old    Jeremy Byrom (wakerider111)      Join Date: Jul 2006       06-13-2011, 1:10 AM Reply
i have not physically done this, but you would have to mount them with the outside slots. hyperlite systems have a choice to mount them with the bolts about 4 inches (hl strata) apart or 6 inches apart (non hl strata). hyperlite's strata has female hardware that slides in the track. slingshot has male hardware. hope this makes sense without pics
Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-13-2011, 4:39 PM Reply
i understand but idk if it will work
Old    Ben Wilcox (benjaminp)      Join Date: Nov 2008       06-13-2011, 8:44 PM Reply
Why would you have to mount them with the outside slots? Hardware comes with the bindings, so you would be getting Hyperlite hardware, which would be able to be mounted on the inside. The only potential problem is a difference in track size here, which would be relatively easy to check with a quick trip to a boardshop.
Old    Hunter Louisiana (Musgrove)      Join Date: Dec 2010       06-14-2011, 9:38 AM Reply
i dont have a local pro shop
Old    Small Light (stephan)      Join Date: Nov 2002       06-14-2011, 10:01 AM Reply
http://www.wakeworld.com/forum/showthread.php?t=787701
There you go, there are like 5 people on that thread saying that they use other bindings with the Strata system.
