Old     (Tjay)      Join Date: May 2011       06-08-2011, 8:52 PM Reply
I am wanting to ad an on board charger to system.
Currently have 5 group 27 batteries.
1 battery for boat electronics/starting.
4 baterries for stereo. 2 (Parallel) A... seperated by perko (2 more Parallel) B..... or.... ALL
Setup with 200 amp relay to connect the 1 battery for start/electronics. to either A or B for charging when on water.
Question? If I get a prosport 20 3 bank will it work? And would it be hooked up? One lead goes to start, one lead to 2 batteries A and one lead to 2 batteries B?
Hope I didnt loose you in the explanation of setup
Is prosport 20 the charger that is best for this, or is there something better?
Thanks again
Old    Earmark Marine (david_e_m)      Join Date: Jul 2008       06-09-2011, 6:00 AM Reply
Tjay,
In this case either a 2 or 3-bank charger will function the same. Assuming that you have five batteries because you are going to regularly deeply discharge four of them, I see problems. With 375 amp/hours of collective capacity you need a 40 amp charger. You could run a 20 amp charger into the ground and you aren't supplying the current needed for the batteries to properly desulphate.
David
Earmark Marine
Old     (Tjay)      Join Date: May 2011       06-09-2011, 11:20 AM Reply
Thanks for the info
What would a good 40 amp charger be?
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       06-09-2011, 11:42 AM Reply
This one would not be a "good one" it would be the "best one"
Give them a call as they do have refurbed units for a significant discount.
http://www.progressivedyn.com/prod_d..._pd2040_1.html
Old    Earmark Marine (david_e_m)      Join Date: Jul 2008       06-09-2011, 1:28 PM Reply
We use the Inteli-Power chargers for anything larger than 20 amps. They come in 30, 40, 50, 60, and 80 amp models.
David
Earmark Marine
