Old     (fozz)      Join Date: Apr 2011       05-31-2011, 5:04 PM Reply
I think I can get away with 1/0 gauge, but I want to make sure.
My amps are:
Diamond D5 1200.1 Class D - Will be running at 1 ohm producing 1200w RMS
2 Diamond D3 600.4 - One of them is bridged 300x2RMS, the other running 75Wx4RMS
The distance from the batteries to the amps will be around 6'. Is 1/0 Gauge for the power and ground enough or should I go up to a 2/0?
I've found it difficult to find distribution blocks for 2/0.
Any idea of what fuse size I should be running with this? Is a 250 amp breaker enough?
Old     (bendow)      Join Date: Sep 2005       06-03-2011, 5:25 AM Reply
You definitely don't need 00ga.
I'd do a quality 0ga wire, 300amp breaker at the battery>fused distribution block with (1) 0ga input and (3) 4ga outputs, 100amp fuses for the 600.4's and 125amp fuse for the 1200.1
Old     (frosty2469)      Join Date: Apr 2010       06-05-2011, 5:19 PM Reply
http://www.bcae1.com/images/swfs/sys...nassistant.swf
Old     (murphy_smith)      Join Date: Dec 2005       06-05-2011, 5:31 PM Reply
You are right in saying that it is very difficult to find a dist block that will accommodate wire larger than 1/0.
You can always run two 0 gauge power lines to the dist block. Take a look at this dist block - it will allow you to do what I just mentioned
http://www.darvex.com/store/pc/Sting...ock-26p796.htm
Old     (talltigeguy)      Join Date: Sep 2003       06-05-2011, 6:10 PM Reply
And that is a pretty good deal on one as well.
