Old     (wiegs)      Join Date: Sep 2010       05-20-2011, 6:21 PM Reply
I just finished installing 4 polk db651 speakers. I replaced the factory deck with a kenwood kmr-440u. When I crank the volume the deck turns off and then back on. Do the speakers take too much power and I need an amp?
Old     (ian_ashton)      Join Date: Jul 2008       05-21-2011, 5:51 AM Reply
Sounds like one of the speakers might be shorting out.
I assume you have each speaker wired to its own channel of the headunit, right?
Disconnect all of the speakers and test them one at a time.
If it happens only on one of the speakers, you've found your problem.
Old     (david_e_m)      Join Date: Jul 2008       05-21-2011, 6:29 AM Reply
If you wired at 2-ohms (paralleled speakers off a single channel) or you mixed a positive from one channel with a negative from another channel or you have a bad ground or you have low voltage...all potential causes.
Double check your voltage at the HU, check the chassis ground and then hook up a single speaker only one speaker at a time and test. Something will become evident.
David
Earmark Marine
