Old     (wakeworld)      Join Date: Jan 1997       10-09-2012, 10:05 AM Reply
What's with the piece of wood with the WakeWorld stickers?
Old     (wakerider111)      Join Date: Jul 2006       10-09-2012, 12:44 PM Reply
that is my DIY balance board. had some stickers and extra wake catalogs to cut up (more specifically the Powell wake pics) and made a collage graphic on top with clear grip tape
did ya notice the red wakeworld coozie on my drink by the computer along with the green foam hands that i got from the first couple of Powell Bro stocks? good times
Old     (MICAH_HARPER)      Join Date: Apr 2010       02-05-2013, 8:53 AM Reply
$2.00 per hook and i made the rack on the bottom a while back with some 2x4's and dial rods
Old     (countryguy1717)      Join Date: May 2013       06-10-2013, 9:36 AM Reply
+1 for the 1.19 hooks at home depot. Get some plastic anhors and you're gtg
Old     (ldr)      Join Date: Nov 2002       06-11-2013, 12:31 PM Reply
Here's ours
Old     (bboozer)      Join Date: Apr 2007       06-18-2013, 7:32 PM Reply
These are pictures of mine. Our garage has square steel posts that support a laminated beam, so I used some U bolts to attach 2x10's to the posts I used wood dowels that I drilled the holes on an angle (that was the tricky part) then I glued them in and added foam pipe insulation....I used mighty putty to attach the brackets for the closet rod between the columns to hang jackets up.
http://db.tt/gDo4oKK8
http://db.tt/ALprnvNC
http://db.tt/nwUzG9rq
Old     (dhill)      Join Date: Aug 2010       06-18-2013, 8:48 PM Reply
very simple, and similar to many others within this thread. simple pvc elbow within 2x4's that are screwed into the wall. holds everything aside from my coolers, which sit under the rack. side benefit, everything dries pretty quickly.
Old     (Gnargnar)      Join Date: Aug 2012       08-08-2013, 3:37 PM Reply
Finally got the garage semi set-up. Hooks are 2$ a piece from harbor freight. And yes that's my competitive hula hoop.
Old     (ivectoryou)      Join Date: May 2007       08-13-2013, 9:24 AM Reply
Here are the racks I built. I like these because they take up zero space on our garage wall and keep the boards well out of the way of any accidental damage. I can reach them from the floor or the boat. My wife can reach them using a short step-stool or from inside the boat. I think we are on year 4 or 5 and I have no complaints. T-bars were purchased at Home Depot and then I just bought some cheap pipe insulation to use for the padding.
Old     (Bumpass1)      Join Date: Oct 2010       10-20-2013, 5:24 PM Reply
Here is a picture of the setup I built out of scrap I had laying around. Holds everything for the boat in one spot.
