Old    Dave (bcrider)      Join Date: Apr 2006       05-19-2011, 1:27 PM Reply
For the people that don't know it's an HSE style volume control app.
Does it work well and what settings have you put it to work the best.?
I also see there is a new one called Cycle Sound. Anyone tried this one?
Old    P A (flattirenotube)      Join Date: May 2007       05-19-2011, 6:23 PM Reply
I used it quite a bit, and think it works great. I use it on the Road bike setting and then adjust the sliders as necessary
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       05-19-2011, 7:21 PM Reply
Same here
I just get the boat running set the max volume you want with the radio then slide the low volume slider almost all the way down.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       05-19-2011, 7:23 PM Reply
Looking forward to using it... used it a lot for snowboarding and was very impressed with how responsive it is.
Old    Taft Leissner (tl7)      Join Date: Feb 2005       05-19-2011, 11:51 PM Reply
I somehow got the two level settings on top of each other, and now I can't separate them. Has anyone done this and if so how do you get them apart?
Old    Shawn (helinut)      Join Date: Apr 2007       05-20-2011, 9:11 AM Reply
Turn your phone down manually. This should bring the sliders apart. I had the same issue and I'm pretty sure that's how I solved it.
Old    BLAIR BARHAM (jonblarc7)      Join Date: Jul 2006       05-20-2011, 12:35 PM Reply
I'm pretty sure thats what I did too. Just use the volume on the side of the phone.
