Old    David Mason (rocketman)      Join Date: Feb 2003       04-28-2011, 9:59 PM Reply
Pic request - please post pics of any board racks, DIY or bought, used to hold the boards in the garage. I'm sure there are those of you out there that have blingy racks for the garage. Please post.
Old    Bevan (stxr_racer)      Join Date: Jun 2006       04-29-2011, 4:16 AM Reply
Here's mine..
Old    Jon Hunter (hunter660)      Join Date: Aug 2007       04-29-2011, 4:53 AM Reply
Old    Aaron (aarond0083)      Join Date: Apr 2007       04-29-2011, 7:19 AM Reply
Nice job Jon with the PVC.
I made mine with Rubbermaid shelving brackets and pipe insulation. I can move the shelving brackets up and down any time to change the config or add more if need be.
Old    David Mason (rocketman)      Join Date: Feb 2003       04-29-2011, 12:48 PM Reply
These are all pretty cool, so thanks for the pics. When I started looking into it, I was leaning torwards the Rubbermaid shelving brackets for simplicity, but wanted to 1) have it angled like all the other ones above to help keep them in place, and 2) protect the board from the metal. Aaron's got issue #2 covered though.
Bevan, how did you drill the angle through the 2x4 board?
Old    Brett Burrows (Riteride)      Join Date: Sep 2010       04-29-2011, 12:57 PM Reply
For all you Malibu guys here are some sick storage racks...
Old    Jason Smith (snowslider76)      Join Date: Mar 2002       04-29-2011, 1:10 PM Reply
I just use ladder racks, .99 cents at any hardware store, 2 per board.
Old    Hate N Pain (hatepain)      Join Date: Aug 2006       04-29-2011, 1:49 PM Reply
I used this except it mounted directly to the wall. They cost about $5-$7 and have worked perfectly for either surf or wake boards.
Old     (moto817)      Join Date: Jan 2011       04-29-2011, 2:46 PM Reply
Jason your garage looks like mine LOL. I think its time i make some craigslist ads =-)
Old    Ryan (ryanw209)      Join Date: Jan 2010       05-18-2011, 8:48 AM Reply
Hunter660- Thanks for the idea!
*Measurements are for pipe cuts only and do not include fittings.
Old    Matthew Bird (ldr)      Join Date: Nov 2002       05-18-2011, 10:13 AM Reply
This is an old picture of the racks my dad built for our boat garage. He wanted it to be more like what you would see in a wakeboard shop.
Old    Austin (austin)      Join Date: Apr 2010       05-18-2011, 10:23 AM Reply
Mine's definitely not "blingy," but here it is:
Old    A-dub (behindtheboat)      Join Date: Aug 2006       05-18-2011, 10:27 AM Reply
just did mine over the weekend. Home Depot sells padded brackets that worked perfectly, and they screw into the studs. They have angled ones that worked better for boards, and then a straight out version with lip that you then can put a shelf on. They are beefy, padded, and hold 50lbs. I'll try and load a pic.
Old    Derek (camassanger)      Join Date: Oct 2009       05-18-2011, 6:50 PM Reply
A-dub, maybe we did the same thing:
Old    Ryan (ryanw209)      Join Date: Jan 2010       05-18-2011, 8:57 PM Reply
Derek - I used those for my 2 snowboards originally but with bindings on they seemed to be just below the tipping point. How are they with a wakeboard with bindings?
Old    Derek (camassanger)      Join Date: Oct 2009       05-19-2011, 7:49 AM Reply
Ryan, They work fine. They dont feel like they're going to tip at all. BTW, I was at WalMart last night in the tools/hardware aisle and saw that they had even larger hooks, just like the ones I have above, maybe 8" instead of 6" and they're black (my preference). They were $1 each. Hope this helps...
Old    Pierre Hetu (power1982)      Join Date: May 2010       05-22-2011, 5:10 PM Reply
Thought I would share ... made of plywood, painted, door foam from home depot for cushion, and screwed to the roof of the garage for easy access while loading the boat.
