Old    Steve (NuBu)      Join Date: Apr 2010       04-25-2011, 3:19 PM Reply
I have 4 Wetsounds Pro 60 tower speakers. 3 of the 4 work just fine and sound great but all of the sudden I'm getting no sound out of the 4th. All of my other speakers in the boat, sub, amps, work fine. There is no sound at all coming from the 4th tower speaker. Maybe a connection issue? if so how do I check it?
Old    Tim White (wetsounds1)      Join Date: Jan 2006       04-25-2011, 3:22 PM Reply
steve,
give our tech support a call at 877-938-7757 and ask for Gyver
Tim
Wet Sounds
Old    Steve (NuBu)      Join Date: Apr 2010       04-25-2011, 3:32 PM Reply
Thank you very much Tim, I really appreciate that. I will call him. Changing subjects a little, do you think the Revolutions are worth the upgrade from what I have?
Old    Tim White (wetsounds1)      Join Date: Jan 2006       04-25-2011, 3:52 PM Reply
No prob, gyver can walk you through over the phone or get an RA to send it in to see whats going on with it.
The REV 8 is going to give you 8 inch mid bass drivers in the same size housing you have. Plus the new Rev Tech technolgy we have put in them. So 4 REV 8's will be a LOT more volume if you decide to upgrade
Tim
Wet Sounds
Old    Sparky Jay (wake_upppp)      Join Date: Nov 2003       04-25-2011, 4:05 PM Reply
Swap a known good speaker over to the one that isnt working. At least you will be able to isolate either the speaker or the feed/wiring is the problem.
Old    TigeMike (chpthril)      Join Date: Oct 2007       04-25-2011, 5:49 PM Reply
Unscrew the blue part of the connector and see if by chance one the of the wires has worked loose. If the leads will reach, swap that speakers lead with the one next to it and see is the problem stays or moves.
