Old    Chaun Keating (big_poppa_pump)      Join Date: Apr 2002       04-14-2011, 12:53 PM Reply
Anyone know how to identify the particulars about a prop. I think mine was replaced right before I bought it 10-some years ago so its probably not the standard size/pitch that came on 99 x-stars.
On the end of the hub next to the prop nut are the numbers 14 , 204 ( or maybe 20A) , cup, and 1 1/8
Alongside the length of the hub are are three tick marks ''' , 17, and 130 but the three is really off centered below the 10 and then 99.
So the 1 1/8 is the shaft size. I *think* that its a 14X17 OJ. 99 is probably the year of manufacture.
Reason I ask is because I'm thinking of going with an ACME 1235 but I'd like to see if I can sell my old one. I don't really need a spare since this one has lasted nearly a decade without a ding in it but I want to be able to identify it correctly on ebay or whatnot.
Also curious what folks would think a used 4 blade inboard prop would be worth in good condition.
Thanks.
Old    Bruce Mac (brucemac)      Join Date: Dec 2005       04-14-2011, 2:55 PM Reply
shoot ejojprop@aol.com an email and he can tell you for sure
if it's in good shape and hasn't been repaired, i'm guessing $150-200 maybe? really depends on it's characteristics as to it's value. someone might soak it up for a spare.
Old    Jeff DeVeer (Jeff)      Join Date: May 2010       04-14-2011, 6:53 PM Reply
I have what sounds like the same prop on my '00 230VRS. I was confused by the markings too and emailed OJ last year. This is what Eric said:
The 14 X 20 "A" was the stock propeller and is actually a 14 X 18 stamped 14 X 20 "A". The propeller was made in September of 1999, 9 99. This propeller is a left hand rotation with a 1 1/8" bore.
Old    Jeff DeVeer (Jeff)      Join Date: May 2010       04-14-2011, 7:00 PM Reply
Oh, and my prop had "999" on it which corresponds to the date of manufacture that Eric mentioned above. So, I would assume that yours is one month older than mine. Not sure what the 17 and 30 indicate though. I don't remember markings along the length of the hub on mine but I haven't looked closely at it since about last July.
Old    Eric Johnson (ej_ojprop)      Join Date: Feb 2009       04-15-2011, 6:16 AM Reply
Chaun - Sent you an email back, Jeff is correct, the 14 X 20 is a 14 X 18. As I mentioned in the email I would suggest trying our 14.25 X 14.5 LC 1 1/8" FUSION 4-blade.
Old    Jeff DeVeer (Jeff)      Join Date: May 2010       04-15-2011, 7:23 AM Reply
Sorry, I guess I should have said yours is 1 month newer than mine.
Old    Chaun Keating (big_poppa_pump)      Join Date: Apr 2002       04-15-2011, 2:00 PM Reply
Thanks Eric and Jeff. Putting the Fusion on the list of props to check out this weekend.
Old    corey king (snowboardcorey)      Join Date: Jan 2004       04-15-2011, 2:27 PM Reply
I'll second the 14.25x14.5 Fusion, my buddy runs it on his X-1 and my other buddy runs the 14.25x14.5 XMP on his. I havent ridden/driven them side by side to really compare the two but both get the job done well.
Old    mojo            04-15-2011, 5:36 PM Reply
First off keep current prop as spare. Second, go with 14.5x14.25. I have a 1464 which is 14.5x13.5 and is great with tons of weight, but on the deep end for regular weight.
Old    Chaun Keating (big_poppa_pump)      Join Date: Apr 2002       04-16-2011, 5:34 PM Reply
I'd just as soon sell it rather than have it cluttering up my garage. Its not like I'd swap one out at the lake anyhow.
Old    mojo            04-16-2011, 5:53 PM Reply
When u damage ur prop and want to use the Boat youll kick yourself.
