Old    Tim (srock)      Join Date: Mar 2002       04-14-2011, 11:31 AM Reply
My Krypt board rack has the 1 5/8 tube mount. The rack with boards wants to rotate slowly after an afternoon run across the lake about 6 miles. What are others doing to prevent this. I don't want to over-tighten the clamp.
Old    Swatguy (xstarrider)      Join Date: Jun 2007       04-14-2011, 12:39 PM Reply
You can get a piece of bike innertube and put it inside you clamp around the tower leg to make it a bit more sung. However you can't really over tighten the clamps. They need to be super snug.
Old    Tim (srock)      Join Date: Mar 2002       04-14-2011, 1:49 PM Reply
It came with a black rubber insert. I think maybe drilling through the bracket and tower and inserting a pin would work but I am hesitant to do that.
Old    Fred (olmoomba)      Join Date: Apr 2010       04-14-2011, 2:00 PM Reply
I would sacrifice the innertube just to snug it up better and wrench down on the clamps.
Better than an unwanted hole in the tower.
Old    Tim (srock)      Join Date: Mar 2002       04-14-2011, 2:09 PM Reply
I still have room to crank down on my clamp but not much. Maybe I misunderstood, I'm not gaining anything unless you mean I should make it thicker and add the innertube over the insert correct???
I have a dead innertube on my workbench.
Old    Ian Brown (wakereviews)      Join Date: Sep 2006       04-14-2011, 2:16 PM Reply
Put the innertube on first, then the insert then the clamp. That should do the trick!
Old    Tim (srock)      Join Date: Mar 2002       04-14-2011, 2:23 PM Reply
Got it now, I'll give it a try. Thanks.
Old    Matt Dico (dorK)      Join Date: Oct 2010       04-14-2011, 4:19 PM Reply
You could also linish where the clamp meets together. If you take 2-4mm off it will clamp on tight.
Old    Tim (srock)      Join Date: Mar 2002       04-18-2011, 8:28 AM Reply
The problem is not being able to snug the clamp its the ability to tighten the bolts enough. I'm worried about shearing one.
Old    Matt Dico (dorK)      Join Date: Oct 2010       04-18-2011, 3:47 PM Reply
You could also linish where the clamp meets together. If you take 2-4mm off it will clamp on tight, Hopefully without shearing the bolts.
Old    Ken Land (bulletlines)      Join Date: Apr 2005       04-18-2011, 3:51 PM Reply
srock,
Sorry to hear about the trouble you are having mounting the clamp without slipping. Unfortunately, tubing size is not always the exact same throughout a tower; there are tubing size discrepancies throughout the tubing of every tower; I have personally seen up to 1/8". I have 2 options that can solve your slippage:
1. move it to a different spot that has a larger tubing diameter (usually not desirable).
2. wrap one time electrical/duct tape around the tubing (this will usually get the job done)
Ken Land
Bullet Lines/Krypt Towers
Old    Tim (srock)      Join Date: Mar 2002       04-19-2011, 5:37 AM Reply
If if have space between the clamp halves I'm going to put a little more torque onto the clamp fasteners. If not I'll add tape. That may resolve the problem. I'll let everyone know but have to make a trip to the lake house first. Thanks.
