Old    Matthew Bird (ldr)      Join Date: Nov 2002       04-13-2011, 7:56 AM Reply
I remember reading somewhere that Perfect Pass Can read the water temp but i've never been able to find out how. For those with Perfect Pass are you able to read water temp and how do you access it in the menu?
Old    Jeff D (Jeff)      Join Date: May 2010       04-13-2011, 8:32 AM Reply
Do you have paddlewheel or StarGazer (GPS)? If StarGazer then you can't get water temp because the temp sensor is on the paddlewheel.
Old    Matthew Bird (ldr)      Join Date: Nov 2002       04-13-2011, 8:54 AM Reply
Paddlewheel with multiline display
Old    Richard (nauty)      Join Date: Feb 2004       04-13-2011, 9:59 AM Reply
Press the menu and up button at the same time. This pulls up a menu. Then press the menu button twice to highlight the "system info" line. Then press the up button to see the system info. This will have the water temp. Press menu to exit back to the main screen when you're done.
Old    Matthew Bird (ldr)      Join Date: Nov 2002       04-13-2011, 10:02 AM Reply
Thanks Richard
Old    Bret Ski (younguns44)      Join Date: Jan 2010       04-13-2011, 7:27 PM Reply
I was talking to perfect pass and they told me that you could plug the paddle wheel into the stargazer and get the water temp
