Old     (michridr69)      Join Date: Dec 2008       04-03-2011, 12:14 PM Reply
Hey all, i have the hardest time trying to make a decent wave with this boat, i dont surf but my g/f is getting pretty good and im trying to make the wave a little bigger and shapely. Any info would be greatly appreciated. Thanks!
Old     (islander033)      Join Date: May 2008       04-04-2011, 7:15 AM Reply
What's your current setup and surf speed?
Old     (westsidarider)      Join Date: Feb 2003       04-05-2011, 10:13 PM Reply
If you have all 4 tanks..... fill both the mid and front tank all the way as well as the rear tank on whichever side your surfing on. Then add another sack on the seat in the rear on the same side ur surfing as well as a sack in the bow. then drop the wedge and run about 10-11 mph. Should be pretty dialed at that point. Whatever you do from there make sure u add an even amount of weight to the front and rear.
Old     (michridr69)      Join Date: Dec 2008       04-11-2011, 1:33 PM Reply
thanks jason, ive been running bow, mid, and left with no extra weight, also the wedge at the peak click. Is that where the wedge should be??
Old     (westsidarider)      Join Date: Feb 2003       04-12-2011, 7:59 PM Reply
Not sure what you mean by peak click. We usually only click back up a bit for wakeboarding. When surfing clicking back up on the wedge it shortens the wave and makes it too steep. Ideally if you want the best possible wave you should run an extra 1000 lbs and no wedge at all
Old     (cjh1669)      Join Date: Apr 2005       04-12-2011, 8:03 PM Reply
The LSV will easily hold an 1100lbs bag in the locker, add a pair of those
