Old     (ess3489)      Join Date: May 2009       03-20-2011, 4:05 PM Reply
2003 supra 22 ssv boat and have upgraded the rear locker ballast to 750lbs in each locker. usualy fill the surf side locker to 750lbs and put an additional 600lbs on the rear surf side seat/corner area. and i fill the center stock ballast full to 650lbs.
my questions:
1) is this the best way to weight this boat for maximum surf wave? if not any sugestions? i have a few extra 300-500 lb bags just not sure where to put them or if i need them.
2) is the 650lb bag in the center front locker good enough? is it worth upgrading to the gravity games 1180lb center sac or is that to much bow weight and the 650 is fine?
Old     (redsupralaunch)      Join Date: Aug 2002       03-20-2011, 5:50 PM Reply
Yes ugrading the front bag to 1150lb will help make the wake longer
Old     (dreamer)      Join Date: Nov 2008       03-21-2011, 4:37 PM Reply
Place a 400-750 pound sac on top of the ski locker between you windsheild. We had the 1150 in the locker but could probably only get 1000 #'s in it before it pushed the front cushion up but we would then add a 275# sac on top of the locker between the windsheild.
Get your additional 600 sac angled half up on the rear sundeck and half down on the rear seat for best results.
