Old    Bryon (ladbg)      Join Date: Mar 2010       02-22-2011, 12:45 PM Reply
Anyone use a motorized ball valve in their ballast system. I have a couple in mind but would like input from some one with first hand experience. I did a forum search and did not come up with anything.
Old    Duffy Mahoney (duffymahoney)      Join Date: Sep 2008       02-22-2011, 12:53 PM Reply
They would be great but are expensive. I think that's why no one has put them in.
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       02-22-2011, 1:51 PM Reply
I know that someone has used them before and I am pretty sure that I saw them on this site. I will try and find the post.
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       02-22-2011, 1:59 PM Reply
http://www.wakeworld.com/forum/showt...highlight=asco
Old    Bryon (ladbg)      Join Date: Mar 2010       02-22-2011, 4:57 PM Reply
Thanks for the info. I just ordered one of these:[URL="http://catalog.farmchem.com/acatalog/Spraying_Systems_12_Volt_Electric_Ball_Valves.html"
Looks like a well made valve will see how it works.
Old    Murphy Smith (murphy_smith)      Join Date: Dec 2005       02-22-2011, 6:22 PM Reply
Cool - I am glad that I could help.
I think it is important that you have a manual (fail safe) way to shut of the water inflow into your boat. If that electrical valve is the only line of defense and it fails in the open position you may have a problem on your hands.
Old    Spencer (spencerwm)      Join Date: Feb 2009       02-22-2011, 10:37 PM Reply
What are you using the ball valve for in your system?
Old    Bryon (ladbg)      Join Date: Mar 2010       02-23-2011, 5:14 AM Reply
I have a 2006 supra 24 with the 2000 gph rule pump running through a 3/4" sprinkler valve to fill the center sac and use a 1200 gph and 1" line to pump out. I already added two more pumps and thru hulls for the side sacs so the rule is only used to fill the center. My plan is to change out the 3/4" fill line to 1" and plumb in place the MOV motor operated valve in place of the restrictive sprinkler valve. With this I have a positive shutoff and no need to modify the scoop or mess with a loop. Little more money but it is only one valve. Should dramaticaly improve fill time.
Old    Spencer (spencerwm)      Join Date: Feb 2009       02-23-2011, 3:29 PM Reply
That works. Yeah that is about the only way to get around changing the scoop strainer to the mushroom style thru-hull fitting.
