If you edge too hard (i.e. 90 degrees to the boat) you will get pulled off of your edge and will flatten out the board. You will go up b/c you are going fast but to get real air you need to edge up the wake which means a lot less than 90 degrees (exception: Darin Shapiro when doing a raley). Get Higher Education and watch the angles the pro's take.
