Old    BWillks            11-07-2010, 7:03 PM Reply
Is it possible to fit 35 inch bfgoodrich tires on a 4 inch rancho lift?
Old    Chris (worththewake)      Join Date: Nov 2006       11-07-2010, 7:11 PM Reply
I would think so, I'm looking at doing a 4 inch lift with 35's
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       11-07-2010, 7:17 PM Reply
It will be tight and you might have some rubbing. Getting wheels with the right offset and backspacing will be really important in pulling it off.
Old    Joe (ilikebeaverandboats)      Join Date: Jul 2007       11-07-2010, 7:31 PM Reply
yea that should fit. make sure you get the right backspacing like nu bu said.
Old    Michael ImObersteg (Michael)      Join Date: Mar 2010       11-07-2010, 10:59 PM Reply
so im going to say no, i have a rancho on my 2500 HD silverado and i dont think 35s would fit at all.. My mom also has an 02 suburban with a 6 inch lift and she barley fits 35's. but i could be wrong
Old    scott clark (snwmot)      Join Date: Sep 2006       11-08-2010, 2:50 AM Reply
can i ask why ur going with rancho?
Old    BWillks            11-08-2010, 7:57 AM Reply
Well im not forsure, i was just curious about them. Do you have another one in mind i should check out?
Old    Michael ImObersteg (Michael)      Join Date: Mar 2010       11-08-2010, 10:21 AM Reply
RCD Makes a good 6 inch lift.
Old    dave Noti_dad (noti_dad)      Join Date: Jul 2003       11-08-2010, 10:35 AM Reply
35's with a 4" Rancho. Front Bars are tweaked another inch and front lower valance is trimmed on the corner. No problems with rubbing on full turn/lock to lock.
Old    Timmy! (timmyb)      Join Date: Apr 2007       11-08-2010, 11:07 AM Reply
Truck looks awesome Dave! There are some people putting 35's without any lift so a 4" will for sure work.
Old    John Bauer (jonyb)      Join Date: Nov 2008       11-08-2010, 1:21 PM Reply
Depends on whether or not it's a 1500 or 2500HD.
If it's a 1500, no, the fenders are too squared off in the front and you won't be able to turn. I did a 7.5" on my 1500 and 35's barely fit. That's also because it was on 22X12's, but the tires were stretched, so that helped.
If it's a 2500HD, you'll need a 6" to clear 35's with aftermarket wheels. A 4" might work, but it'll be stuffed and you'll still have to trim.
Check out "Pro Installz" on facebook. That's our page of the installs and lifts we've done. Lots of GM's on there.
Here's my 08 1500 on 35's with a 7.5" lift:
Old    Brian (viking)      Join Date: Sep 2009       11-11-2010, 9:52 PM Reply
You'll have to crank up the torsion bars on a 4inch to get them to fit and ride quality will be rougher. Go 6in if you want to fit 35's the right way! 33's are about perfect on the 2500HD's with a 4inch from all my research.
Old    scott clark (snwmot)      Join Date: Sep 2006       11-12-2010, 1:33 PM Reply
RCD makes the best lift for chevy or gmc hands down nothing else compares and after a year with that rancho it's gonna be squeaking horribly.
Old    hyperlite (tims72)      Join Date: Apr 2008       11-13-2010, 10:10 PM Reply
check out www.cognitomotorsports.com ask for justin. his lifts are heavy duty. he swaps out the upper a arms and uses heim jts instead of ball jts. the longer a arms help with the caster on your alignment. he also offers a hd stearing staibilizer kit that is well worth the money. as far as 35's with a four inch lift w/o touching the torsion bars, it wont fit. 35's with a six inch lift will fit just fine. i crank the torsion bars just enough to get the truck sitting level. if you have a 1500 you will definately need a six and need to crank the torsion bars. if you research diesel forums or other forums and ask about cognito people always have positive comments
Old    Charles (chas)      Join Date: Feb 2002       11-14-2010, 7:00 AM Reply
Mine on 33's is really close when turning.
Old    John Bauer (jonyb)      Join Date: Nov 2008       11-14-2010, 7:31 AM Reply
hyperlite, the 07.5+ 1500's are non-torsion bar trucks, so the lift, steering, control arms, and everything under the truck is completely different.
The OP still hasn't returned and advised what truck he has either.
Old    BWillks            11-14-2010, 2:33 PM Reply
This is why i thought it was possible
Old    Nu Bu (05mobiuslsv)      Join Date: Apr 2006       11-14-2010, 3:07 PM Reply
Of course they fit just sitting there, full lock is where the issue come to play. It looks like you were reasonable with the offset and they don't stick out 3-4" like on these other guys trucks that are posting pics up on here.
Old    Charles (chas)      Join Date: Feb 2002       11-14-2010, 4:06 PM Reply
The offset will make all the differance.
Old    David Griffith (davidggriffith)      Join Date: Sep 2008       11-14-2010, 5:53 PM Reply
John who makes the wheels you put on your truck they look good
Old    Mattt (motorcitymatt)      Join Date: Feb 2007       11-14-2010, 6:18 PM Reply
All the trucks above look awesome! It's nice to see trucks, looking like trucks! Big meaty tires, tons of LIFT!!!! I've never been a fan of the lowered, slammed look. I don't understand why anyone with 4wd would lower their ride.
After reading the post "what wheels should I put on my NEW denali?" All those trucks looked so ghetto! Just my two bits...........
Old    hyperlite (tims72)      Join Date: Apr 2008       11-14-2010, 6:58 PM Reply
john b the your right the 07 and newer are not torsions. he didnt say what year make or model he ha. so i was only giving him my personal experience with my 2500 chevy diesel.
Old    John Bauer (jonyb)      Join Date: Nov 2008       11-15-2010, 11:22 AM Reply
David Griffith, those are Ion Forged Terminator's in 22X12. They're discontinued already so they can only be found used, unless a dealer has a few sets they're sitting on.
bwilks, nu bu is right, just because it's sitting there doesn't mean it can turn. Evidently you've got a 1500 1/2 ton since you won't reply to the questions about what truck you have.
If you happen to read this post, search "Pro Installz" on facebook. There's a listing of all the trucks we've lifted, and they all have descriptions of what lift, and which wheel/tire combo was used.
Old    Scott (chilidog)      Join Date: Dec 2007       11-17-2010, 6:31 PM Reply
A 2009 Dodge will fit 35s with no lift........(ok a $50 1 1/2" leveling kit up front) No rub sorry I couldn't resist......
