Old    D. Cooper (dcooper)      Join Date: Mar 2005       10-23-2010, 5:39 PM Reply
So I went winterize my 2009 SSV and found a notice saying that fogging the engine can damage the catalytic converter. It also says to fog each cylinder by removing the sparks plugs. Anyone have any suggestions? It seems like a pain to remove each spark plug but I will if needed...
Old    Matt (mattscraft)      Join Date: May 2009       10-24-2010, 6:54 AM Reply
Ahh, the age old question, to fog or not to fog. If you fog with the choke out method you risk fauling your plugs also. The reason on a Cat system not to use the fog/choke method is you will mess up your O2 sensors, you prob have 2 for each side. I have used the spray fogging oil in each cylinder for the last 3 years, plugs are fine as well as the O2 sensors. Ir is kind of a pain, but really only takes about 15 minutes to do it.
Old    Doug (docdrs)      Join Date: Aug 2004       10-24-2010, 1:27 PM Reply
Remove all plugs, fog each cylinder for 2 or 3 seconds then bump engine over for 2 seconds , then reinstall plugs...02
