don't throw it over your back shoulder, squaring the wakes is a quick fix, but it's also the way you're "throwing it", throw it square, if not more over your lead shoulder. Put your arm up as if you're about to flex your bicep to someone, that is how you want to be at the peak of the wake. slightly looking over your lead shoulder if you need to look to spot, like you're looking at your bicep, should also help keep you square.
