Old     (eshowcase)      Join Date: Mar 2010       10-07-2010, 2:30 PM Reply
I never found good pics or an easy how-to on this, so decided to write one up. This is a quick and dirty method for budget boats... hopefully it helps out a few folks. This was a DIY install of a Monster tower onto a '92 SNOB.
http://helgedom.com/2010/05/quick-an...keboard-tower/
cheers.
Old     (baitkiller)      Join Date: Jan 2010       10-07-2010, 4:01 PM Reply
Any port in a storm.
That should work fine for quite a while. Some paint or least some Thompsons on that 2x4 may get a few more years out of it.
It was kind of you to post the how-to.
Old     (otown_dave)      Join Date: Dec 2007       10-07-2010, 6:36 PM Reply
Mine are made of 2x4 Oak from a commercial pallet & run all the way to the floor from the gunnel Boxed top & bottom.
Old     (bill_airjunky)      Join Date: Apr 2002       10-07-2010, 9:39 PM Reply
Nice writeup.
After having a couple of boats with similar installs, I have wondered if a top plate would do the install some good. Inevitably our boats have developed small cracks in the gelcoat around the tower bracket. Some not so bad, & others not so good. A top plate made of billet, carbon fiber, or even fiberglass or plastic would spread the load across the top, just like it does on the bottom side. And it could be made to look good too.
Old     (otown_dave)      Join Date: Dec 2007       10-20-2010, 8:17 PM Reply
Like this?
Old     (david_e_m)      Join Date: Jul 2008       10-20-2010, 8:53 PM Reply
Avoid pine as it will dry out and split over time. Even pressure treated pine will eventually have issues under stress. Definitely seal the blocks. Be sure to radius the corners and radius the edges of the blocks that fit up under and against the deck cap. While glassing in the blocks is the preferred method you can use a Tiger Hair, Kitty Hair or similar filler containing fiberglass strands to seat the blocks in place. As this cures it will fill any void between the blocks and deck cap with some structural integrity.
Old     (bill_airjunky)      Join Date: Apr 2002       10-20-2010, 9:16 PM Reply
Quite a bit more substantial than I thought, Dave. But looks like it's doing a good job of spreading the load out over a larger area. Would be interesting to see the rest of the tower too.
