Old    Matt Sharp (matts0246)      Join Date: Mar 2010       10-19-2010, 6:14 PM Reply
i was going to try and winterize my boat this year and was wondering have do i run the antifreeze threw the motor?
Old    Tim C (lifetimewarranty)      Join Date: Oct 2008       10-19-2010, 7:47 PM Reply
Just drain it. No water = nothing to freeze in the block.
Old    Carl (SugarFree)      Join Date: Aug 2010       10-19-2010, 9:55 PM Reply
you should never throw antifreeze... it could get into somebody's eyes
Old     (JamesPB22)      Join Date: Mar 2010       10-19-2010, 10:17 PM Reply
Classsic!!! Good pickup and GOLD Reply!!!
Old    Art (rallyart)      Join Date: Nov 2006       10-20-2010, 1:52 PM Reply
You put RV or Marine antifreeze (propylene glycol) in a pail and suck it up through a fake-aLake, or you pour some in through the thermostat opening after you take the housing off and the thermostat out. First you would drain the block and any heaters or shower lines you might have.
I don't put antifreeze in mine. I just drain everything well and then drive the trailered boat around to slosh out what ever might have been left in a crevasse.
Old    Matt Sharp (matts0246)      Join Date: Mar 2010       10-20-2010, 4:37 PM Reply
ok what do i need to do to winterize my v-drive its the walter drive
Old    Doug (docdrs)      Join Date: Aug 2004       10-20-2010, 5:17 PM Reply
after you drain your block, heater ,shower , remove your jtube from your thermostat housing and pour the antifreeze in it with a funnel....there is no need to remove the housing or the t stat......... as far as the walters vdrive remove the intake and exit hose and blow or suck out the water , no need to remove the drain plugs nothing will come out after you do the previous
