Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       09-28-2010, 10:31 AM Reply
I've pulled the hard tanks from my 2006 malibu vride and replaced them with fly high 750s. I'm getting leaking from the flow rite disconnects when I REALLY fill the bags (i.e. bulging full where you could bounce a quarter on them). Am I overfilling the bags or are my quick disconnects bad?
Old    Spencer (spencerwm)      Join Date: Feb 2009       09-28-2010, 10:57 AM Reply
Is the water coming from the bag or from the flow-rite connection? First take a look at the W736 fittings in the bag and add a little rubber cement to the threads. When your motor heats up the bag port (black threaded insert ring) will expand and may allow a leak. If it is your Flow-Rite connection try changing out the O-Ring on the W736 fittings. You can find larger ones in the kitchen section at home depot. Home that helps.
Old    Shawndoggy (shawndoggy)      Join Date: Nov 2009       09-28-2010, 11:16 AM Reply
Yeah, it's an O-Ring issue. Thanks for the tip, I'll try the beefier rings and see if it helps.
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       10-01-2010, 8:44 PM Reply
Try some plumber's tape on the threads. That solved my leak, and did not cement the fittings in place, either.
