Old    Cliff (ord27)      Join Date: Oct 2005       09-22-2010, 10:31 AM Reply
I am considering installing my own french drains. I thought that it would make the install easier if I could quickly figure the elevation both at the drain and at the discharge site. Do any of yall know of an iphone app that shows elevation in inches? The only ones that I found were either in feet or meters.
thanks
Old    Tyler Steeb (tsteeb)      Join Date: Aug 2006       09-22-2010, 10:34 AM Reply
just use the feet one and convert
Old    Cliff (ord27)      Join Date: Oct 2005       09-22-2010, 10:40 AM Reply
that will work as long as it gives the fraction. I guess that i was assuming that it would only give the whole #
Old    Jason Henrichs (vette74)      Join Date: Jun 2008       09-23-2010, 6:38 AM Reply
I hate to say it but they don't have an app for an iphone that is anywhere near that accurate. You need to rent survey equipment I rented a level for $55 for a week.
Old    Blabelmooch (blabel)      Join Date: Jul 2001       09-23-2010, 6:53 AM Reply
Yeah I wouldn't rely on that for accuracy. I downloaded the level and thought it would be cool to use it when leveling the toy hauler. It sucks! Not even close!
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       09-23-2010, 9:45 AM Reply
all you need is a couple of stakes, a piece of twine and a good level. It wil be accurate enough.
hammer the stakes in the ground . tie the twine around them...level the twine...measure down to the ground at whatever point you want....you can then tell the elevation.
