Old     (mxflyer281)      Join Date: Oct 2007       09-20-2010, 1:48 PM Reply
So I decided to get a CWB vibe 142 to try on wake just wondering for an opinions on how it rides behind the boat? Is it heavy I wanted to try something with flex. Just figured if I didn't like it I would make it a rail board.
Old     (stephan)      Join Date: Nov 2002       09-20-2010, 2:23 PM Reply
It rides really well behind the boat. I think its best suited for someone with solid fundamentals, that rides a little faster and has a large wake. It is definitely not a heavy board. I've ridden mine behind the boat but mostly use it for rails/cable, it is perfect for that.
Old     (wake77)      Join Date: Jan 2009       09-20-2010, 8:18 PM Reply
I got the same board in May. I think it is very fun behind the boat. I came from a Covin, so the Vibe was much slower, but after a set or two, I adjusted. Took me about two W2W to adjust to the flex, and it is a bit slippery when you first ride it. It will boost you off the wake.
